Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-07-2007, 11:35 PM   #1
Cobraboy
CF Senior Member
Cobraboy's Avatar
Default Help with C5 fuse box wiring
Quote:
RAP for an amp WITH the stock HU still installed:
Pull up the fuse box (two or three screws and a plastic clip), on the grey connector (C2) pins E10 and F10 (both orange, I used F10 since it was on the bottom row and easier to get at) supply 12V RAP power to the stock radio amps. Even if you have a new amp installed, the radio will still be telling RAP to stay energized.
Assuming this is refering to the fuse box in the passenger footwell. I pulled mine up and don't see any grey connector. Well, there is a grey connector near the top, but it has 3 large red wires into it. Also, what does C2 & F10 refer to; I don't see any numbering on mine. Other than the connectors at the top of the box, all with large red wires, there doesn't appear to be any others. Am I looking in the wrong place?
Quote:
How do I get the acc power for my h/u?
if you look in the passenger footwell, pull out the cover and look in the top left corner. There will be a small plug with three wires (orange, yellow, & black) that are just taped up. Check out this schematic to see which fuses they use, but the yellow wire is the +12V switched, and that I am sure of.
Does anyone know what fuse this is connected to? I shorted it out while trying to determine if it was live with the key on (it was!). I don't know which fuse I blew without taking them all out and checking them. Yellow is definitely 12V switched. Anybody know what the orange one is? The black seems to be ground.
thanks,
Rick
Cobraboy is offline   Reply With Quote
Old 06-08-2007, 01:59 AM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
off hand not sure which fuse its tied into, but i know one is 12 volt switched the other is 12 volt consnant and yes black is ground
as far as your amp turn on wire if you have a vert or coupe there is deff a remote/antenna wire at the back of the radio that you could use, which when using the PAC adapter you tap into it.
Furthermore if you are trying to add amps and not using the pac adapter with the stock radio, stop now and get the pac adapter
pentavolvo is offline   Reply With Quote
Reload this Page Help with C5 fuse box wiring
Tags
2004, 35, audio, box, c5, corvette, fuse, fuses, ground, list, locate, panel, plugs, schmatic, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C5 and general audio FAQ scott_fx Audio/Electronics 172 11-06-2011 10:25 AM
Piaa 1100X Lights & C5 Mounting Kits Tuan Le C5 Parts for Sale/Wanted 59 07-02-2004 03:23 AM
Need help on wiring with PIAA light install. Longhorn FRC C5 Tech 23 01-13-2004 06:44 PM
Please help me locate connector for changer, see Pics. RPOZ4Z C5 Tech 14 12-01-2001 02:57 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
