Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-07-2007, 10:03 PM   #1
W89
CF Member
Default radio install problems
Help please ! took the bose out of my 84 and installed a pioneer,got the ac / battery wires hooked up radio comes on but I have a grey and a red or pink wire left over what are they for ? tester says their not hot.The radio had everything but wiring directions in the box(my luck)I also have a blue hot wire comming out of the radio dont know on that is for either ? if anyone could help
W89 is offline   Reply With Quote
Old 06-07-2007, 10:48 PM   #2
Repzard
CF Senior Member
Repzard's Avatar
Ok im going to take a shot at this but I could be wrong.
Blue wire is for power int
And the Pink and Grey wires could be for clock memory
Repzard is offline   Reply With Quote
Old 06-07-2007, 11:05 PM   #3
Hooked on Vettes
CF Senior Member
Are the colors and the wires you posted on the back of your new radio or are these the wires that were used by the Bose radio harness?
For the Bose radio there are two pink wires from the harness. The source was the same from the Bose radio. When you turned the Bose radio on, 12 volts is on both Pink wires. The Pink wires energized the Bose Speaker Relay and also energized the Antenna Relay.
The gray wire is for dimming the display.
I don't see any mention of a Blue wire. They list a Dark Blue wire and a Light Blue wire used in the speaker wiring.
Hooked on Vettes is offline   Reply With Quote
Old 06-07-2007, 11:07 PM   #4
AGENT 86
CF Senior Member
AGENT 86's Avatar
http://members.shaw.ca/dankai/Radio.pdf
AGENT 86 is offline   Reply With Quote
Old 06-08-2007, 12:04 AM   #5
W89
CF Member
agent 86 couldnt get the pdf to open? grey wire was for the console/info lights, pink is maybe for the bose relay which I dont need? where the heck is the antenna wire that is what the blue wire goes to I think.Since we're talking electrical after over a year of fixing up my 84 from when I bought it I took it on a test run when I turned the lights on it blew the fuse in the INST what the heck is that, the cluster and lights come on except for the front side markers.I have no idea why this one is.
Old 06-08-2007, 12:28 AM   #6
AGENT 86
CF Senior Member
AGENT 86's Avatar
You need Adobe reader to open the file, it's free on the net. The antenna wire is pink, my memory says it was a single wire.
Old 06-08-2007, 01:47 AM   #7
C4boy
CF Senior Member
C4boy's Avatar
W89, I can't tell if you're asking about wires in the car's harness or coming from your new radio. I'm assuming you used a new wiring harness kit that plugs into the vette harness?
Blue wire off the new radio is usually for the power antenna - which would go to pink on your vette. You may end up with additional wires from your radio that you won't use (i.e. leads for remote amp turn
on, etc.).
Re: Your front marker lights - Check under your dash around the steering column for connections that aren't connected. I don't know the color code off hand.
C4boy is offline   Reply With Quote
Old 06-08-2007, 03:03 AM   #8
CentralCoaster
CF Senior Member
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The bose has two pinks, one for antenna relay, one for the external amp relay.
You can't simply used the stock wiring harness unless you replace the speakers.
If you're lazy you can wire them to the puny pre-amp wires at the Bose speaker boxes. I ran new wire.
CentralCoaster is offline   Reply With Quote
Old 06-08-2007, 11:17 PM   #9
W89
CF Member
I hook the blue hot wire from the radio to the pink wire and it pops a fuse?so I"ll just run a new wire to the antenna relay which I assume its the relay that is underneath the trim in the back near the hatch? I need to invest in something better than this Haynes manual.Thank you like always guys.just want to drive this thing been working on it for over a year, I want to post pics but its the hated 84 ,with a body kit,really hated on it,so I'll just keep all the hard work to myself
Old 06-09-2007, 04:11 AM   #10
Happydad
CF Senior Member
Happydad's Avatar
I may be wrong but.. Does'nt the blue wire off the back of the radio go to the amp (RS or Rm.. I forget what terminal) for the subwoofers in some cases with aftermarket recievers/stereo systems..Just a Thought
Happydad is offline   Reply With Quote
Old 06-09-2007, 02:22 PM   #11
CentralCoaster
CF Senior Member
Quote:
Either or. I think all new stereos have a 2nd wire that turns the antenna on only when you're on the tuner, and off when in CD mode. If you don't have that, you just hook it up to the amp wire and it goes up any time the radio is on.
I don't even know if the antenna relay will work like a normal system. It's Bose. Right is left, up is down, and red is blue.
Reload this Page radio install problems
Tags
corvette, install, problem, radio
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Aftermarket XM Radio Install C5 XTC C5 General 15 11-16-2004 10:35 PM
Radio Install problem!!!! NEED HELP!!! YZ450FRACER165 C3 Tech/Performance 9 03-28-2004 07:05 PM
How to install HID yipieee!!! 71'AirStrike C3 Tech/Performance 23 05-27-2003 02:31 AM
Calling all '84 to '89 owners with aftermarket stereos - what did you install? TheCorvetteKid C4 Tech/Performance 49 04-08-2003 02:18 AM
"how-to-install" hydrobooster dial-up beware 71'AirStrike C3 Tech/Performance 22 09-24-2002 04:54 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
