Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-06-2007, 03:02 PM   #1
MR.WaynesWorld
CF Senior Member
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Support Corvetteforum!
MR.WaynesWorld's Avatar
Location: The real question is; When you turn your car on, does it return the favor..
Send a message via MSN to MR.WaynesWorld
Default What Gauge Wire for Amp
What gauge wire should I use for a Infinity Reference 5350A 5 Channel Amp. Should I go with 4 or 8 gauge power and ground?
I'm going to mount the amp on the back wall of a 99 coupe. Being that I only see grounding wires 3-5 feet that would not be enough to go to the B piller of the seat track for a good ground. Any other suggestions were I can get a good ground within 3 feet of the back wall?
MR.WaynesWorld is offline   Reply With Quote
Old 06-06-2007, 03:21 PM   #2
Kale
CF Senior Member
Kale's Avatar
8 gauge will handle it, but, do 4 gauge anyway - future expansion possibility.
Kale is offline   Reply With Quote
Old 06-06-2007, 03:23 PM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
IMO do 4 gauge 8 will cut it close with that amp. Just run a longer ground thats what I do
pentavolvo is offline   Reply With Quote
Old 06-06-2007, 03:26 PM   #4
MR.WaynesWorld
CF Senior Member
Quote:
So I can run a longer then 4 feet ground wire to reach the B Piller?
Any idea were I can get bulk black ground 4 gauge wire?
Old 06-06-2007, 03:28 PM   #5
TheKomoman
CF Senior Member
TheKomoman's Avatar
TheKomoman TheKomoman
Yes, you can run longer than 4'. Ideally the ground should be short as possible, but you can usually get away with longer.
I have used darvex.com for bulk wiring, connectors, etc.
TheKomoman is offline   Reply With Quote
Old 06-06-2007, 03:42 PM   #6
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
Thats where going with a larger gauge wire helps. You can run a longer ground with a larger gauge
DPG is offline   Reply With Quote
Old 06-06-2007, 03:47 PM   #7
MR.WaynesWorld
CF Senior Member
Thanks Guys....
One last questions, for now at least, what gauge wire should I use from the Amp to the speakers, 12 or 16 gauge speaker wire.
Old 06-06-2007, 04:02 PM   #8
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
16 will be fine
Old 06-06-2007, 04:05 PM   #9
pentavolvo
CF Senior Member
pentavolvo's Avatar
16 gauge for the win
Old 06-06-2007, 04:07 PM   #10
MR.WaynesWorld
CF Senior Member
Quote:
Originally Posted by DPG View Post
16 will be fine
Thanks Dave. This will be my second major Audio mod to the wifes car. The head unit mod I did a couple of months ago looks easy compared to this one.
Hey at least it is giving me pratice before I do my Vert.
Old 06-06-2007, 05:14 PM   #11
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
there you go. The vettes are pretty easy to work on compared to other cars
Old 06-07-2007, 03:33 PM   #12
Fasthotrod
CF Senior Member
Fasthotrod's Avatar
UnderRADAR
Send a message via AIM to Fasthotrod
I dropped a ground down the right side bin and out to the frame.
There are small ground lugs back there, one on either side up on the frame next to the mufflers. If I had my camera, I'd take a snapshot and post it for ya.
Mark
Fasthotrod is offline   Reply With Quote
Old 06-07-2007, 03:37 PM   #13
MR.WaynesWorld
CF Senior Member
Mark
Thanks Mark. When I get ready to install the amp I'll be sure to look on the under side for a grounding point. I take it you had to drill a hole for the ground wire to get it there.
Reload this Page What Gauge Wire for Amp
Tags
5350a, gauge, reference, wire
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What to do for dimming lights.. BayouVette Audio/Electronics 19 04-12-2004 04:58 PM
What Gauge Wire. knesbitt Audio/Electronics 17 03-06-2003 01:40 AM
Wierd stereo problem: Bass amp cuts off under high volume?!? OliverM5 Audio/Electronics 11 09-11-2002 11:12 AM
how to get power lines through the firewall on 89 vette for amp? dmalhi1 C4 General Discussion 36 06-12-2002 09:42 PM
FOR ALL OF YOU LOOKING FOR A THEFT DETERRENT couldbefun C3 Tech/Performance 20 11-30-2001 12:20 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
