Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-12-2007, 05:24 AM   #1
1fstc5vette
CF Senior Member
1fstc5vette's Avatar
Default JENSEN Brake Override Code for VM series Units
Attention to anyone with a Jensen VM9311,VM9411, VM9511TS and/or 9021TS:
You can bypass the parking brake security feature for free! Without paying for those pulse boxes or any other additional hardware!
Yes, the little black boxes work, but they're a scam because you can do this for free using the Jensen factory override code.
So if that isn't clear enough, let me further explain. The code is a permanent way of disabling the brake override on the jensen vm series multimedia head- units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable the blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, it's a little more complicating because you can't see the settings your changing.
I tried to make this as clear as possible and post this thread since I was getting more than a few pms regarding overriding the H/U. Hopefully this helps you out and if you have questions, private message me or post here.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
1fstc5vette is offline   Reply With Quote
Old 05-12-2007, 10:11 PM   #2
MarineGunny
CF Senior Member
MarineGunny's Avatar
You are the man !!!!! Worked like a charm. Once again this forum ROCKS !!!!!!!!!
Gunny
MarineGunny is offline   Reply With Quote
Old 05-15-2007, 04:50 AM   #3
1fstc5vette
CF Senior Member
Quote:
Gunny
Glad I could help I think one of the best options with this code is being able to turn macrovision off to watch all pirated dvds
Reload this Page JENSEN Brake Override Code for VM series Units
Tags
code, factory, jensen, override
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
