I am in the middle of installing a mono sub amp into my 2000 Coupe. Got the stock Bose HU out of the dash and the wiring harness doesn't seem to match up with the PAC-AOEM VET 1 module I have. Am I missing something? I have a CD changer, does this mean I have a different harness in my HU? Some Pics:
PAC and Radio Harness
PAC Cables
Radio Harness
Radio Rear
As you can see, there's no way the radio's plugs will fit into the PAC plugs, nor will the PAC plugs fit into the radio's rear. (I know the black and white plugs on the radio's harness separate, but it still doesn't work). The radio and its plugs seem to have separating plastic dividers between the pins whereas the PAC is straight across...PLEASE HELP!!!
Never mind, I'm an idiot. I'm straightened out now...I had the wrong plugs out. DUHHHH. Thanks to PAC tech support I'm flying right again. Please me on the head!
MODS, PLEASE DELETE THIS THREAD. THANKS!
Reason: Delete request
OK, I\\\'ll be a man and take the humiliation! It\\\'s all good now...got the wiring done and the sub kicks some serious bASS! I will gladly impart my hard-won knowledge to the less fortunate next time, and I will post pics when I get everything \\\"cleaned\\\" up. Glad I could add to your enterrainment
__________________ No, try not. Do, or do not. There is no try.
