Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-08-2007, 04:05 AM   #1
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
Default Early C4 speaker mounting
I've got an 88 that was originally equipped with the Bose system, but now has an aftermarket setup.
I've got a set of Pioneer 6x9's for the rear, and a lot of what I'm reading says that these should drop in and bolt right up. They drop in no problem, but the mount holes come nowhere near lining up so they just kind of sit there loose.
I could probably go through some trouble of making some mounts, but I'd like to hear about how others have gotten around this issue. Is there an off-the-shelf mount kit I can buy to secure the speakers?
The C4 Audio FAQ also mentions that an 8 inch sub for the rear, but I don't see how one could possibly fit in there. Maybe it was just talking about using the rear compartment behind the seat, but I'm not interested in doing that. If they could be made to fit into the original speaker location without cutting, I'd probably do that as long as I could mount them.
Basically I'm just looking for a solution that leaves me with well-secured rear speakers that does not involve cutting or custom fabrication, although a commercial mount is fine. I would also be interested in hearing from someone who is using rear 6x9's in a car that originally had Bose, with no aftermarket mount.
Tourney3p0 is offline   Reply With Quote
Old 04-09-2007, 01:09 PM   #2
Aardwolf
CF Senior Member
Aardwolf's Avatar
Aardwolf is offline   Reply With Quote
Old 04-10-2007, 10:48 AM   #3
auto_cran
CF Senior Member
I just finished doing this to my '88 a few weeks ago - I put some Alpine 6x9s in the rear - replacing my Bose units.
Like you, I was disappointed that the new speakers did not line up with the exisiting holes (although the speakers fit nicely in place!). I also didn't want to drill new holes.
What I did worked just fine: got some plastic tie downs and threaded them up threw the holes and into the speaker holes. Be sure to pull them TIGHT. With four in place for each speaker, that speaker isn't moving. Cut the access plastic off, put the grill back on, and job is done.
I'm sure it's not the most professional way, but it works.
Good luck!
Chris
1988 Chevrolet Corvette 35th Anniversary #1941/2050
1989 Pontiac Turbo Trans Am #760 (1818 miles)
1983 Delorean DMC-12
1986 Toyota Supra MKII
1985 Kawasaki Eliminator ZL900
auto_cran is offline   Reply With Quote
Old 04-11-2007, 01:38 AM   #4
bogus
CF Senior Member
Send a message via Yahoo to bogus
contact www.vette2vette.com and get some OEM Delco base speaker mounts.
bogus is offline   Reply With Quote
Old 04-11-2007, 03:26 PM   #5
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
Thanks for the responses guys. At least I have confirmation now that the holes don't line up. As I said earlier, I've read some people mention that theirs lined up perfectly.
I'm going to assume maybe they had the mounts Bogus mentioned. I'll get in touch with them. Thanks again.
Reload this Page Early C4 speaker mounting
Tags
c4, corvette, mount, mounting, speaker
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Early C4 Door Panel Speaker Pods snoopdan Audio/Electronics 10 12-21-2004 01:17 AM
What is the largest driver people have put in the doors of early c4's bart15 Audio/Electronics 11 01-30-2004 02:47 PM
Stereo done, early c4, no more bose crap! Kale Audio/Electronics 10 12-03-2001 02:46 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
