Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-08-2007, 01:35 AM   #1
gator79
CF Senior Member
gator79's Avatar
Default subwoofer confusion
I purchased a Kicker CVR 10 and have a question on hooking it up. it has dual 2 ohm voice coils. with a 2 chanel amp can you just hook one chanel to each coil? the instructions that came with it show it wired either parallel (this would give me 1 ohm load) or series (this would give me 4 ohms load) both diagrams just show one set of leads going to the amp. I have a 200 watt 2 chanel amp now that might not be enough. what would be a good resonably priced amp? it is rated at 300 rms and 600 peak
__________________
1971 BB vert (undergoing frame off resto, still)
1981 coupe 450 hp 383 stroker (sold)
1936 Chevy 2 door sedan street rod
1950 Ford F1
1950 Chevy pickup (street rod project)
http://www.bayoustatecorvetteclub.com/
gator79 is offline   Reply With Quote
Old 04-08-2007, 03:54 AM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
wire it to 4 ohms, and bridge the amp. this is the best way to do it, that amp will work just make sure you arent clipping your gains
pentavolvo is offline   Reply With Quote
Old 04-08-2007, 10:40 AM   #3
robvuk
CF Senior Member
robvuk's Avatar
Send a message via AIM to robvuk Send a message via Yahoo to robvuk
Quote:
Your amp will deliver the same amount of power bridged into 4 ohms as it does individually into 2 ohms. You also have the advantage of a higher impedance circuit which will give a better damping factor and less speaker line loss.
robvuk is offline   Reply With Quote
Old 04-08-2007, 01:42 PM   #4
gator79
CF Senior Member
gator79's Avatar
Default wired
ok mine will be wired like this
http://www.crutchfield.com/learningc...pe=2%2DChannel
where does the second voice coil get its input from? it looks like it is just hooked up to itself. is there a conection in the speaker itself?
Old 04-08-2007, 03:56 PM   #5
robvuk
CF Senior Member
robvuk's Avatar
That is correct for 4ohm operation. The two speaker coils are now wired in SERIES as opposed to PARALLEL. Using a dc signal for example, the signal goes into one voice coil and out to the in of the other and out back to the amp.
Old 04-08-2007, 03:58 PM   #6
01QSZ06
CF Senior Member
Send a message via Yahoo to 01QSZ06
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Good site! Tells you how to wire anything....
01QSZ06 is offline   Reply With Quote
Reload this Page subwoofer confusion
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
