Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-05-2007, 11:02 PM   #1
sgjr
CF Member
Default brand new Eclipse 7100 troubles
Just installed my system (see previous posts recently) and went for a ride tonight with the Mrs. The Eclipse 7100 started acting up on left turns. The power didn't cut out; instead, the the head unit acted like it couldn't read the CD. So I switched to Sirius, the same thing happened. The further I drove the worse the problem progressed. Soon, it didn't work at all and appeared to be searching for a signal albeit from an Ipod, CD or radio. Called the firm that sold me the unit and I'll be getting a replacement tomorrow. I guess everyone has a problem but doggonit, spending so much time installing I don't want to redue something again. Oh well, just have to vent.
sgjr is offline   Reply With Quote
Old 04-05-2007, 11:11 PM   #2
ICULUKN-C5
CF Senior Member
ICULUKN-C5's Avatar
Send a message via AIM to ICULUKN-C5
Maybe a ground or pinched wire?
ICULUKN-C5 is offline   Reply With Quote
Old 04-05-2007, 11:14 PM   #3
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Quote:
And to add.. the second time into the dash is WAY easier than the first. You'll wonder why it took you so long the first time. While you're in there, check all your splices, connectors, etc. They've had a little time to shake and rock and roll with some driving now, good time to check 'em.
TheKomoman is offline   Reply With Quote
Old 04-06-2007, 06:19 PM   #4
sgjr
CF Member
Looks like my own stupidity. I piggy backed the head unit with a laser blinder. As the 7100 works flawlessly, the piggy back must have reduced the needed amps to run correctly. Also checked the ground wires and all other connections. Here I am knocking the Eclipse when I should have been knocking myself. Get to take the new unit back with apologies.
Old 04-10-2007, 08:25 AM   #5
carlton_fritz
CF Senior Member
St. Jude Donor '08-'09
carlton_fritz's Avatar
Quote:
How did you get a warranty when you installed it yourself? I'd love that option.
carlton_fritz is offline   Reply With Quote
Old 04-10-2007, 11:10 AM   #6
sgjr
CF Member
The business i purchased the gear from assisted in the install. The fellow who installed the head unit insisted it was the a faulty unit. The speakers were MUCH cheaper online so I installed those and the amps, with box. Still uncertain if i have enough air circulating through the box. Those JL amps will apparenlty cut out if they get too hot.
Old 04-10-2007, 11:45 AM   #7
TheKomoman
CF Senior Member
TheKomoman's Avatar
Quote:
Self-install does not void a warranty unless the manufacturer specifically states that. Big difference between self-install from a legit dealer vs trying to get a warranty honored after gray-market purchase.
Old 04-10-2007, 08:07 PM   #8
carlton_fritz
CF Senior Member
Quote:
Which is what Eclipse did the last I checked. Granted I haven't worked in car audio for just over a year. My friend that owns the store does keep me informed. I visit often just to check on the new stuff.
Old 04-10-2007, 08:16 PM   #9
TheKomoman
CF Senior Member
TheKomoman's Avatar
I'm certainly no Eclipse expert so it could very well be they have lines that have a warranty requirement for professional install, but since Crutchfield sells Eclipse (including the 7100 mentioned here) and their primary market is self-install, that's what I based my comment on.
Old 04-10-2007, 10:56 PM   #10
carlton_fritz
CF Senior Member
I suspect the warranty from Crutchfield is a Crutchfield warranty, not an Eclipse warranty.
Old 04-11-2007, 01:45 AM   #11
bogus
CF Senior Member
Send a message via Yahoo to bogus
I know that JL Audio and Rockford will push the warrantee up if a dealer installs it. The base warrantee is 90 days... I think the JLA warrantee is over a year if dealer installed and 3 years for RF. Or it used to be.
bogus is offline   Reply With Quote
Reload this Page brand new Eclipse 7100 troubles
Tags
7100, eclipse
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
