Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-04-2007, 10:11 PM   #1
leghumper
CF Senior Member
leghumper's Avatar
Location: This post copyright, TLH Inc. All rights reserved.
Default sirius/xm
what do you have and where do you have yours located. I have to get a new reciever for my 95
leghumper is offline   Reply With Quote
Old 04-04-2007, 10:14 PM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
locate what? the antenna?
There is this great section here with tons of audio related answers: Audio/Electronics Forum
bogus is offline   Reply With Quote
Old 04-05-2007, 09:11 AM   #3
Vette Gator
CF Senior Member
Vette Gator's Avatar
My car came with a Kenwood Sirius-compatible head unit in the dash. I was told that the Sirius receiver was somewhere behind the breadbox, but I've never looked for it. The antenna is attached to the rear deck just behind the convertible deck lid.
Vette Gator is offline   Reply With Quote
Old 04-05-2007, 09:57 PM   #4
96RedRoadster
CF Senior Member
96RedRoadster's Avatar
I have the S50 Sirius that I plug into the cigarette lighter. Nothing is mounted - I keep it all in a Crown Royal bag (luckily I happened to have an empty one ) and take it to the car only on longer cruises.
I also bought the home kit so I can use the system in my office, home or the car kit.
When I travel it also records several hours of programming that I playback on airplanes, jogging, etc.
Best Buy wanted to drill here and bolt there and I said - CYA
It's worked well for me for 2 years now and the interior remains stock looking.
96RedRoadster is offline   Reply With Quote
Old 04-06-2007, 12:27 AM   #5
ZfidyONE-84
CF Senior Member
ZfidyONE-84's Avatar
fomoco007
i actually have a modified sharkfin antenna from a 2007 mercury montego, i gutted the inside, and stuck my stock XM antenna into the enpty shell... i have no problems with signal loss, and looks pretty good
ZfidyONE-84 is offline   Reply With Quote
Old 04-06-2007, 12:43 AM   #6
Rex Ruby
CF Senior Member
Philly 'Burbs Events Coordinator
Rex Ruby's Avatar
Quote:
I have XM but I understand XM and Sirus are merging. I mounted my antenna on the rear hatch glass up near where the above is mounted but on the glass on the left side. No wire showing. The receiver is mounted to the left of the Bose unit. I took off the dash piece and mounted a (custom bent) bracket to 2 bolts that hold the Bose (or the HVAC unit, can't remember). So the bracket comes out from under the dash cover to hold the receiver. The power is hot wired in, no cig plug!
Rex Ruby is offline   Reply With Quote
Old 04-06-2007, 12:51 AM   #7
Goldcylon
Goldcylon's Avatar
I think it looks good too, like a small shark fin!! A good location
__________________
GOLDCYLON - 91 ZR-1 #2014
380 P&P&PCed,Ported Heads,Jeal Long tubes,/Corsas/FIKSE FM-5s /LED TLs, Hellas, F/R Baer Eradaspeed Rotors with CE/GS RED/BL calipers,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM STG V /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer AVIC Nav system,Brey-Krause HB,Sub Bar,DRM Coilovers
Goldcylon is offline   Reply With Quote
Old 04-06-2007, 12:53 AM   #8
ZfidyONE-84
CF Senior Member
fomoco007
Quote:
i still have some clean up work to do with the wiring, but when i installed it i had just peeled off half the paper for the tape, but it is very solid, and has been tested up to around........ well i'm not gonna say, but it was not quite to triple digits
and i was looking for something that would fit on the rear window flap, and all the ones i saw on ebay, and other european cars were about an inch or 2 too long, and the ones from the new freestyle, montego were prefect lenght
Old 04-06-2007, 09:40 AM   #9
finnor
CF Senior Member
finnor's Avatar
96 Convertible with Sirius Starbase
Hardwired into accessory plug, wireless transmit to head unit, antenna under hard tonneau cover.
--Tor
__________________
1991 Acura NSX, Berlina Black / Ivory
Gone:
1992 Dark Red Metallic/Black A4
1996 Bright Aqua Metallic/Black A4
2000 Torch Red/Black 6-speed
2003 Anniversary Red Metallic/Shale 6-speed
2001 Pewter Metallic/Oak 6-speed
1990 Dark Red Metallic/Black A4
2005 Machine Silver/Ebony 6-speed
1996 Sebring Silver Metallic/Black 6-speed
finnor is offline   Reply With Quote
Old 04-06-2007, 11:26 AM   #10
Goldcylon
Goldcylon's Avatar
--Tor
Orange Orbit mod optional!! Actually a very good set up there and you actually use the cassette case holders!!!!!
__________________
Old 04-06-2007, 07:28 PM   #11
ZfidyONE-84
CF Senior Member
fomoco007
looks good, i wish my XM reciever would fit in the little cubby where the power seat adjustment is
Old 04-06-2007, 07:46 PM   #12
fatdog96
Junior Member
fatdog96's Avatar
Here's my mount that I made for my XM myfi out of some polycarb plastic. I work in a plastics machine shop, so that kinda helps. Anyway, I removed the top of the center console and made the inside bracket with a 180 deg. bend that 'hooks' over the lip of the transmission tunnel, then attached all the other parts with some small flat-head screws. I also lined the entire underside of the mount with some self-adhesive felt so there was no worry of scratches... and I didn't have to drill or stick anything to my car.
I also wired mine directly to the accessory leads in the center console (I actually found them when I took the console apart, who knew?), and use the cassette adapter. You can barely see the wire running into the cassette deck from behind the bezel.
fatdog96 is offline   Reply With Quote
Old 04-08-2007, 12:05 PM   #13
BearCreekC6
CF Senior Member
BearCreekC6's Avatar
I just had a Kenwood DNX7100 installed. The salesman talked me into Sirius but I didn't want the antenna on the exterior of the car. After reading several threads on antenna locations, I had it installed under the grill on the dash. The reception was not very good. I spoke to the techs at Kenwood and was told the antenna for XM was much better for that location. It's being installed Monday.
BearCreekC6 is offline   Reply With Quote
Reload this Page sirius/xm
Tags
antenna, corvette, fin, shark
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Xm Wasted Money TOPGON C6 Corvette General Discussion 124 09-29-2005 10:54 AM
Sirius vs. XM RCK1999 Audio/Electronics 16 06-23-2005 09:52 PM
BAH HUMBUG! XM Radio + OnStar Superstar555 C6 Corvette General Discussion 24 12-11-2004 10:57 PM
Did I expect Too Much? (XM Radio) Vettman 1 Audio/Electronics 13 12-07-2004 01:38 AM
XM receiver alternative for C6 (no visible antenna) docrings1 C6 Corvette General Discussion 14 10-13-2004 12:49 AM
XM-Radio/OnStar yukon95 C6 Corvette General Discussion 17 04-21-2004 10:37 AM
Anyone Else Angry About The Exposed XM Antenna? GDP C6 Corvette General Discussion 37 12-11-2003 05:35 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
