Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-10-2007, 12:37 AM   #1
screw991le
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
Send a message via MSN to screw991le
Default Crossover question
I have a set of Infinity 6010cs. It has one extra screw on the Crossover marked -3db. What is that for? The manual says nothing.
screw991le is offline   Reply With Quote
Old 03-10-2007, 12:41 AM   #2
Kale
CF Senior Member
Kale's Avatar
usually there is a switch to mellow out the tweeter... A screw or a little knob?
Kale is offline   Reply With Quote
Old 03-10-2007, 01:15 AM   #3
screw991le
CF Senior Member
screw991le's Avatar
Quote:
It is a screw terminal for wire, just one marked -3db
Old 03-10-2007, 01:28 AM   #4
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
u can either connect the positive lead of the tweeter to the tweet positive or the -3db it pulls down the level of the tweeter making it less harsh. Just put it at the -3db now and save yourself the hassle of messing with it later.
pentavolvo is offline   Reply With Quote
Old 03-10-2007, 06:40 AM   #5
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Quote:
It's on p. 4 of the instructions, in the section on connecting the wires to the crossover.
Vis Croceus is offline   Reply With Quote
Old 03-10-2007, 08:36 AM   #6
screw991le
CF Senior Member
screw991le's Avatar
Quote:
I see that, but it does not say what it does. It just tells you what the screw is, that is why I asked what it does as far as sound quality
Old 03-10-2007, 09:05 AM   #7
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
It depends on the position you mount the tweeter. Most of the time time in these small cabins you're better off using it as the tweeters will be relatively close to your ears. Pulling them down 3db is a good idea. My Focal components in my C6 have -3 and -6 on the Xover and I'm going to have to pull the door panel off to go to -6 on the front tweets. They're at -3 now and it's just too much.
TheKomoman is online now   Reply With Quote
Old 03-10-2007, 09:46 AM   #8
screw991le
CF Senior Member
screw991le's Avatar
Thanks for the advise. I mounted the tweets right above the mid, in the center of the panel. So the -3db looks like a good idea. Thanks
Old 03-10-2007, 10:24 AM   #9
Vis Croceus
CF Senior Member
Which part of "To reduce tweeter output level, connect the positive (+) tweeter wire to the -3dB terminal" (p4, 6010cs manual) do you fail to understand?
Old 03-10-2007, 01:38 PM   #10
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
someone woke up on the wrong side of the bed today
scott_fx is offline   Reply With Quote
Old 03-10-2007, 10:13 PM   #11
screw991le
CF Senior Member
screw991le's Avatar
Thats ok Scott. If someone could read, I asked in a later post about sound quality, not what it does.
Reload this Page Crossover question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Interesting Turbo Question. mn_vette C4 Forced Induction/Nitrous 25 12-28-2003 12:10 PM
Here's an odd question I haven't seen on this forum! C3 Tech/Performance 26 09-23-2003 10:38 PM
Crossover pipes - do they reduce interior resonance UK C5 Owner C5 Tech 24 07-10-2003 09:16 PM
X-Pipe question NCC-1701 C5 Z06 Discussion 19 05-29-2003 10:11 PM
Component Speaker Question Randy K Audio/Electronics 40 01-10-2003 03:31 PM
New toys, Stroker question torquejunky Engine Mods 10 04-30-2002 08:18 PM
Question about Corsa X-Pipe Snake Slayer C5 Tech 16 02-17-2002 04:35 PM
Spark Plug/Wire Question btsoom C5 Tech 19 02-06-2002 02:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
