Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2007, 09:55 PM   #1
Anomir
CF Senior Member
Anomir's Avatar
Default Retrofit a OEM Nav unit in C6?
I have an oem nav unit, gps antenna and dvd that I managed to snag. I went to a dealer to be told this cannot be done. They stated I cannot change radios at all, whatever it rolled out of the factory is all you can use.
In my case I have a 6 disc changer. I wanted to switch to the nav unit. I questioned this, because it makes no sense to me WHY you would not allow it. They told me basically, any GM (I assume newer ones, my C5 I switched with no problems.) you cannot change radios and they cannot unlock or change radios. The example the service manager gave me was someone purchasing a pickup with am/fm only, they want a cd/am/fm, they cannot purchase a new one from parts because the computer will not accept it.
I have read on another forum where someone has done the retrofit succesfully and the dealer reprogrammed without issue. So I am at a loss as to what to do (please do not say just go get aftermarket, I would have done that to start with if I wanted to go down that path) does anyone know for sure if the dealer is just WRONG, or that the person on the other forum is wrong.
Anomir is offline   Reply With Quote
Old 03-09-2007, 10:38 PM   #2
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
why don't you ask the person on the other forum how he did it? :-)
scott_fx is offline   Reply With Quote
Old 03-09-2007, 10:43 PM   #3
Anomir
CF Senior Member
Anomir's Avatar
I sent a pm and email, not sure how active he is. I have waited a couple days with no replies.
Old 03-09-2007, 10:50 PM   #4
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
The dealer has to reprogram the radio using Tech II to marry the radio to your VIN. All the GM stock radio pieces are VIN-locked. With most dealers if you provide solid proof-of-purchase they will do the re-programming for whatever charge they use.
That said, my question would be *WHY* you would do this. Aftermarket NAV units are superior in EVERY way - sound quality, ease of use, options.. shall I continue? And I own a factory NAV in my '06 Convertible so I know that of which I speak!
Aftermarket NAV would be no more money, probably less and give you more. Do NOT bother retrofitting factory nav.
One man's (strong) opinion. As always.. YMMV
TheKomoman is offline   Reply With Quote
Old 03-09-2007, 11:05 PM   #5
Anomir
CF Senior Member
Anomir's Avatar
The deal I got was WAY below any aftermarket. The person who sold it to me felt as you do, and I personally prefer the oem. It does not have alot of the features the aftermarkets do, but was as I said MUCH cheaper, and I really do not care about most of the extras the aftermarket units have.
The person from the other forum has responded, basically saying what you did, the dealer obviously does not know what he is doing and go somewhere else. I suppose its quite obvious the dealer also will never touch my car to do any work on it.
Reload this Page Retrofit a OEM Nav unit in C6?
Tags
c6, corvette, factory, nav, navigation, oem, retrofit, retrofitting, system, unit
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
