Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2007, 09:42 PM   #1
auto_cran
CF Senior Member
Default Out with the Bose - in with the Delco. Now got Questions!
Well, I have given up on the stock Bose system in my '88 Anniversary and decided to put in a new unit (non-Bose).
I installed a refurbished Delco CD unit (to keep the stock appearance) and used a GM Cable Adapter to connect the new Delco unit to the existing wiring in the car. So far, so good: the unit powers up just fine, works with the headlights, etc... Just no sound.
I still have the stock Bose speakers, and really wasn't expecting the Delco to work with them. As for replacing them, I want to start with the rears since they are easier to get to, and plan on buying new Sonys tmw. Can I just remove the Bose rears, plop the new ones in, use the exisiting wiring that the was used for the Bose speakers, and expect it all to work? Or is there more to it?
And am I correct that I should not be expecting sound to come from the Bose speakers with the Delco unit?
So far, I have not cut into a single wire - do I need to to get the speakers to work?
Any help would be greatly appreciated!
Chris
1988 Chevrolet Corvette 35th Anniversary #1941/2050
1989 Pontiac Turbo Trans Am #760 (1818 miles)
1983 Delorean DMC-12
1986 Toyota Supra MKII
1985 Kawasaki Eliminator ZL900
auto_cran is offline   Reply With Quote
Old 03-09-2007, 10:02 PM   #2
1991Z07
CF Senior Member
1991Z07's Avatar
I believe you are correct, the Bose will not work with your unit.
The Bose have a line-level input to the speakers, and the speakers have the amps built into them.
Your wires will need to be replaced (I'd just run an additional set, leave the stock stuff as is, in case someone should ever want to get it back to original).
I've had serious thoughts about getting a new head unit for mine that is fully iPod compliant. Speakers are shot anyway, so replacing them is really not an issue.
There used to be a tech article on this somewhere...
1991Z07 is offline   Reply With Quote
Old 03-10-2007, 11:36 AM   #3
nyernga1
CF Senior Member
nyernga1's Avatar
Two schools of thought here. I've seen it written where you need to run seperate speaker wire if you change to non bose. I replaced my head unit with a sony and the speakers with infinities. In the case of the rears, I isolated the speaker from power wires, taped off the power ones and used the OEM speaker wire. I did the same with the door speakers. That was almost 2 years ago and it still plays great.
Am I missing something on sound quality? I doubt that seriously. I can hear it fine with the roof off and at highway speeds.........so unless you're trying out for the DB drags...........keep it simple.
ps: shouold I ever decide to go back to the bose, say if I suffered a sudden head injury, then the power wires are still there.
nyernga1 is offline   Reply With Quote
Old 03-10-2007, 03:43 PM   #4
bogus
CF Senior Member
Send a message via Yahoo to bogus
the bose wiring harness is adaptable, but, why mess with it? It's just as easy, and the wire really isn't right for dealing with speaker level outputs. And it's old... old is bad.
As for replacing the speakers... the bose in 1988 used an enclosure with a 4" driver. It's best to remove the enclosure and use a larger driver. get some 1/4" MDF or hardwood plywood and make what is called a 'baffle'. This is essentially a custom plate designed to interface the speaker to the vehicle.
Another option is to find the OEM Delco speaker baffles. They can be adapted to fit other speaker sizes.
For what it is worth, you really don't want to ruin the Bose enclosures. As much as we hate them, in 20 more years, C4s with working Bose systems will be "original" and more desireable. If nothing else, having the components will be something of value.
bogus is offline   Reply With Quote
Old 03-12-2007, 12:05 PM   #5
auto_cran
CF Senior Member
I took this approach. Once I unplugged the 4 wires from each amp/box combo, I noticed 2 of the wires matched the GM speaker wire specs. Hooked up my (new) speaker to that, and then there was sound!
And like you mentioned, if we ever decide to go back to the original, its all there.
thanks for the help.
Chris
Old 03-12-2007, 03:13 PM   #6
ODIVETTE
CF Senior Member
ODIVETTE's Avatar
Run power to the heavy pink wire that is all by itself....it will power the amps and give you sound. I put a pioneer deck in my 87 and fought with the same problem. You don't need to do anything else.
ODIVETTE is offline   Reply With Quote
Old 03-12-2007, 03:41 PM   #7
Lichen
CF Senior Member
Lichen's Avatar
Replaced mine with an Alpine, and had to use an adaptor to use the Bose speakers. If I were to do it again, I would replace the wiring and use aftermarket speakers. It just doesn't sound that good.
Lichen is offline   Reply With Quote
Old 03-12-2007, 03:56 PM   #8
auto_cran
CF Senior Member
Thanks Lichen and Odivette.
I ended up removing all the Bose speakers/amps.
In back, I put some Alpine 6x9s. Still not sure what to put in the doors. I'm using all the exisiting wiring. So far, things are sounding good.
thanks,
Chris
Old 03-12-2007, 11:23 PM   #9
nyernga1
CF Senior Member
nyernga1's Avatar
thanks,
Chris
I used 4" round Infinities. Not a perfect fit but hey.........who ever says "pull your door panel off and show me your speaker."
Reload this Page Out with the Bose - in with the Delco. Now got Questions!
Tags
1985, boise, corvette, door, show, speakers
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Audio FAQ bogus Audio/Electronics 49 01-31-2012 04:41 PM
DELCO BOSE STEREO BACKLIGHT DHUNT C4 General Discussion 15 07-01-2011 01:00 PM
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 01:59 PM
*Vette parts for sale, some perf./some not. jburnett C4 Parts for Sale/Wanted 47 08-30-2005 02:28 PM
Bose amp removal from doors? Also, new speakers with stock wiring? NoWorries Audio/Electronics 10 11-20-2002 12:26 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
