Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2007, 08:12 PM   #1
dave1981
Junior Member
Default Installation Question?
Where is a good place on the C6 to get power to turn the amp on and off with the ignition?
dave1981 is offline   Reply With Quote
Old 03-09-2007, 08:15 PM   #2
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Quote:
Simple way to do it is to grab one of the switched sources in the fuse box of the passenger footwell. I used the wiper fuse.
If you are interested in RAP functioning (stereo doesn't shut off until you open the door) then you'll need a module like the Peripheral GMRAP. Don't use it to power the amp (just a paranoia note there) but you can use it to trigger and to power an aftermarket head.
TheKomoman is online now   Reply With Quote
Old 03-09-2007, 08:27 PM   #3
dave1981
Junior Member
That sounds alright. Just a side question, Where did you run your power cable in to the cabin and where would you route it, to get it to the back?
Old 03-09-2007, 08:36 PM   #4
TheKomoman
CF Senior Member
TheKomoman's Avatar
My amp (for now) is in the right rear cubbie. I brought the wire through the firewall near the fuse box (had to remove) in a new hole with a grommet and ran it down the right side of the car all the way to the back.
Check out my install thread, which is linked in my sig. Should show you alot of what I did.
__________________
1980 L-82 Dark Claret/Claret
2006 Z51 MN6 Monterey Red/Black/Ebony Convertible
2008 Z06 Velocity Yellow/Ebony
The Official Forum C6 Audio FAQ
Old 03-09-2007, 08:55 PM   #5
dave1981
Junior Member
Ill check it out. Thanks for the info. Hopefully get some pics of my own when its complete.
Old 03-10-2007, 10:41 AM   #6
cleaner145
CF Senior Member
cleaner145's Avatar
I did exactly this but did not have to remove the fuse box. From Dans picture I hit almost the exact spot. The factory grommet was way to tight for me to want to try that route.
cleaner145 is offline   Reply With Quote
Reload this Page Installation Question?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fuel rail cover installation question VT-Sandman C6 Corvette General Discussion 17 06-08-2005 10:25 PM
CD player installation question - Please help!!! 68coupe C3 Tech/Performance 36 02-16-2005 02:52 PM
Another Tremec TKO 5-speed installation question Bullshark C3 Tech/Performance 12 02-14-2005 04:04 AM
Seat Hoop Installation question/help???? Vette 4 Fun C5 General 17 12-06-2004 10:57 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
