Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2007, 06:00 PM   #1
dontpntpool
CF Member
dontpntpool's Avatar
Default Factory Radio Size
Does anyone know the size of the factory radio for the height and width?
Not just the visible area but like edge to edge in this pic.
TIA
dontpntpool is offline   Reply With Quote
Old 03-09-2007, 08:27 PM   #2
C4TOMCAT
CF Senior Member
C4TOMCAT's Avatar
Dimensions
Metal Screw Tab Outside-outside Is 9-5/8 Inches
Metal Case (not Faceplate)is 8.0 Inches Wide
Metal Case Is 3-3/8 Inches High
Metal Case + Faceplate Is 6-1/8 Inches Deep (front Of Flat Faceplate To Longest Case Part Which Is On The Upper Section Of The Radio. Hope This Helps. (sorry About The Caps..eyesight)
faceplate is 8-1/8 inches long, 3-5/8 high
hth.
C4TOMCAT is offline   Reply With Quote
Old 03-09-2007, 08:33 PM   #3
EG@EnglandGreen
Supporting Tuner
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Support Corvetteforum!
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ ____________ 281.464.2800
englandgreen.corp englandgreen
Send a message via ICQ to EG@EnglandGreen Send a message via AIM to EG@EnglandGreen
Tom
EG@EnglandGreen is offline   Reply With Quote
Old 03-09-2007, 09:14 PM   #4
C4TOMCAT
CF Senior Member
C4TOMCAT's Avatar
EG, Hi, listen....do you have any source for the plug assemblies that plug into the rear of the bose radio. I have a picture if that will help but I am SURE you have a radio on the bench to see for yourself.
I need the plugs plus at least 6 inches of pigtail....or if someone has an old harness( burnt etc) that I could get the plug and harness wires out of ....thanks for saying Hi
Old 03-10-2007, 04:43 AM   #5
dontpntpool
CF Member
Quote:
Originally Posted by C4TOMCAT View Post
Dimensions
Thanks Tom that helps, do you know what the measurements of the plastic faceplate H x W?
Old 03-10-2007, 08:20 AM   #6
C4TOMCAT
CF Senior Member
C4TOMCAT's Avatar
edited dimensions
Old 03-10-2007, 12:28 PM   #7
dontpntpool
CF Member
Thanks a lot!
It really helps to have great people that will help you out when your stuck inside because of the snow.
Reload this Page Factory Radio Size
Tags
03, 2004, corvette, dimension, factory, radid, radio, size
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
WANT TO REPLACE BOSE RADIO IN 86 Cruz 86 C4 Tech/Performance 17 02-10-2004 11:22 AM
Size of ..... Finland C4 General Discussion 10 07-21-2002 04:07 AM
Factory Radio or Aftermarket? JoeMacgruder C3 Tech/Performance 26 06-18-2002 11:46 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
