Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2007, 03:39 PM   #1
Fcal
CF Senior Member
Fcal's Avatar
Default Door Panel Problem
OK, today I changed the midrange spkrs in my doors. The driver door went fine, but the passenger door panel wont lock back tight to the door. The plastic pins on the rear lower corner wont lock tight. Everytime I close the door, the panel pops out about 1/4".
Anyone else have this problem?
Fcal is offline   Reply With Quote
Old 03-09-2007, 03:46 PM   #2
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
You may need to replace the fastener. They can be damaged pretty easily if they're not lined up when you re-install. It should be something you can get from the parts window at a nearby dealer. They do wear out and some folks change them pretty much every time they pop the panel off.. though mine have been off & on 3 times so far.
TheKomoman is offline   Reply With Quote
Old 03-09-2007, 03:49 PM   #3
Fcal
CF Senior Member
Fcal's Avatar
Thanks Dan
I already paid a visit to the dealer ($4 a pop). Do the pins come with the receivers that snap into the door
Reload this Page Door Panel Problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Door panel repairs!! no1g8tor C5 Tech 15 08-02-2005 02:33 AM
Door panel problem, can anyone help? JasonBourne C4 General Discussion 10 10-14-2004 10:07 PM
Door panel/window rattle cj68 C5 Tech 18 07-07-2004 12:29 AM
split in new door panel...should they stand behind it? OkeeGuy C3 Tech/Performance 66 04-08-2004 09:26 PM
Door Panel Instln - what a mess! vett70 C3 Tech/Performance 14 12-07-2002 03:36 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
