Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2007, 07:54 AM   #1
1fstc5vette
CF Senior Member
1fstc5vette's Avatar
Default Installed Jensen VM9311TS Indash DVD Player, probs w/ebrake wire!
I just installed my new HU, which is the Jensen VM9311TS Indash DVD/CD player. I messed up buying the GM wiring harness and connecting it to the harness that came with the HU then plugged it into the stock harness. I figured out the hard way that the power lead isn't plug and play so I grounded it on the 22 fuse, but I didn't realize I would lose my stock amp and bose subwoofers. I did some research tonight and found a couple harnesses that allows you to keep the amp and subwoofers but running anywhere from 55-95 dollars. That don't concern me too much, it's the pink wire that says "caution its the law to install this to the emergency brake" that concerns me. I knew that if I installed that wire to the ebrake that it wouldn't let me view the dvd player unless the car was stopped, ebrake applied. Therefore I didn't install the wire and just capped it off, but after I have everything hooked up and pieced back together, I can not watch dvd's at all because of that wire!! I know theres probably not a way around it since the screen is built into the HU, but if anybody knows a way around it where I don't have to hook up that wire to the emergency brake I'd appreciate it. I've never hooked anything up to the ebrake anyways, if you guys have some tips for me any help will be appreciated greatly
1fstc5vette is offline   Reply With Quote
Old 03-09-2007, 08:36 AM   #2
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Just put the wire to ground, that should take care of it.
TheKomoman is offline   Reply With Quote
Old 03-09-2007, 09:32 AM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
actually u migth have to put a switchinline on it, some units if just ran to ground they unit gets smart and says please release ebrake and then reapply it, which is why you need a switch
pentavolvo is offline   Reply With Quote
Old 03-09-2007, 11:12 AM   #4
screw991le
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
Send a message via MSN to screw991le
Also the e-brake's sensor engages with 1 click. So if you pull the brake slightly you won't engage the brake just the sensor.
I learned that on my 99 Z28, when the headlights would come on if I wanted them or not.
One click.
screw991le is offline   Reply With Quote
Old 03-09-2007, 01:08 PM   #5
Ishams00vette
CF Senior Member
Send a message via AIM to Ishams00vette
I HADDDD that exact same screen in my truck... ONE PROBLEM... Ive seen with EVERY ONE who has had that screen is that it will blink out... You will have to turn the car off to get the screen back on. It wont happen at first, but give it a few weeks maybe even a month and you will see it. I got rid of it as fast as I got it!!!
Ishams00vette is offline   Reply With Quote
Old 03-09-2007, 01:08 PM   #6
Ishams00vette
CF Senior Member
Old 03-09-2007, 03:26 PM   #7
screw991le
CF Senior Member
screw991le's Avatar
You can say that again
Old 03-09-2007, 07:34 PM   #8
1fstc5vette
CF Senior Member
Quote:
thats not what I wanted to hear....when you had yours did you put the ebrake wire to a ground or have to hook it up to a toggle switch? I don't want to hook it to the ebrake, that's retarded to only be able to watch a movie when the ebrake is applied. This unit has a blue screen and asks to emerge the ebrake then you can watch the movie, hopefully if I just put the wire to a ground it'll work
Old 03-30-2007, 07:35 PM   #9
1fstc5vette
CF Senior Member
I ordered the soundgate harness to keep my stock amps and subs and installed that today, sounds good, but still don't have my dvd player working because the ebrake wire. Can someone help me out on where to hook up the wire to the ebrake? I've searched and haven't found anything on it...
Old 03-30-2007, 09:30 PM   #10
Fasthotrod
CF Senior Member
Fasthotrod's Avatar
UnderRADAR
Send a message via AIM to Fasthotrod
Well... the manual says:
Parking Brake
Parking Brake Inhibit
When the pink "Parking" wire is connected to the vehicle
brake switch, the front TFT monitor will display video
only when the parking brake sequence is engaged.
Before starting the parking brake sequence, the radio
must be on with the video media disc inserted and
playing.
Parking Brake Sequence
There are two situations that can start the Parking Brake
Sequence (this is the preferred method). The timing
window is between 3 ~ 5 seconds.
• Parking brake is engaged (on) when the vehicle is
started or the accessory/ignition is turned on. To
activate video, the following sequence of events must
be completed:
a. Release parking brake for 3 ~ 5 seconds.
b. Reapply parking brake.
c. Video should be displayed on the TFT monitor
within 1 ~ 2 seconds.
• Parking break is disengaged (off) when the vehicle is
be completed:
a. Set parking brake for 3 ~ 5 seconds.
b. Release parking brake for 3 ~ 5 seconds.
c. Reapply parking brake.
d. Video should be displayed on the TFT monitor
If you want to connect it to your parking brake, then just find the wire that leaves the parking brake switch and tap into it.
If you want to bypass the parking brake switch and activate your HU any time you want, then you need to install a switch that connects that pink wire to ground when you toggle it. Look to Radio Shack or even Wal-Mart to get a small switch to wire in series with that circuit.
If you want to get creative, look for a timer circuit that is activated at startup... should be pretty easy to make it work.
Hope this helps.
Mark
p.s. If you bypass the parking brake circuit and then wreck your car watching DVD's, don't come crying to me.
Fasthotrod is offline   Reply With Quote
Old 04-05-2007, 08:03 PM   #11
1fstc5vette
CF Senior Member
thanks for the post, I didn't want to wire it to a toggle switch for the main purpose that you said. If an accident does accure with the screen up, and it's not wired to your ebrake then you're in some serious trouble depending on how serious the accident is. I was wondering if anybody had pics where they tapped into the ebrake wire, because I still don't know where it's located exactly.
Old 04-23-2007, 06:45 AM   #12
1fstc5vette
CF Senior Member
bump
Old 04-23-2007, 09:39 AM   #13
pentavolvo
CF Senior Member
pentavolvo's Avatar
with the center counsel off the ebrake wire is literally a single wire coming off of the ebrake
Old 04-23-2007, 10:03 AM   #14
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
Quote:
brown wire
DPG is offline   Reply With Quote
Old 05-04-2007, 09:37 AM   #15
1fstc5vette
CF Senior Member
I programmed a code where I could run it without messing with a toggle switch or ebrake/sensor wire. If you have a Jensen model in-dash dvd player and want to do the same shoot me a PM I will let you know, but I will only provide this for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
Old 10-14-2008, 05:01 PM   #16
gmcguy
Junior Member
Ok i got the same dvd player and i tried hooking it up to my ground and now my amp switched to the protection mode. i know i have to get my amp reset to get it to work but i need a detaled description on how to correctly hook up the dvd ground wire (the pink one) please help
gmcguy is offline   Reply With Quote
Reload this Page Installed Jensen VM9311TS Indash DVD Player, probs w/ebrake wire!
Tags
brake, bypass, car, dash, dvd, dvdbypass, engage, ground, jensen, movie, parking, pink, player, radio, vm9311ts, wire, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
