Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-08-2007, 02:45 PM   #1
Kale
CF Senior Member
Kale's Avatar
Default Mid blockage in door mount three ways? c5
Im about to pull the trigger on some three ways,
but I want to know from someone who has tried it -
Does it sound ok? Does it image OK? Since much of the mid will be blocked by door panels.
A picture showing the extent of blocking would be hugely appreciated.
tia.
Kale is offline   Reply With Quote
Old 03-08-2007, 03:26 PM   #2
fej
CF Senior Member
fej's Avatar
Don't have pics bro, but I have a 7" midbass and a 3" dome (which is effectively 4") mounted in the factory location. I had to build a raised wood lip that the bottom of the midrange sits on, which in turn sits just on top of the edge of the basket on the 7" midbass.
The top of my midrange is blocked about 25%. Maybe 20%. I think this can be addressed depending upon what midbass you use, and if you are willing to do a bit of custom work on your mounts in conjunction with a little bit of cutting at the bottom edge of the factory speaker hole to lower the entire assembly another 1" or so. As long as care is taken to make sure that the driver and its motor/cone sit far enough away from the bottom of the door skin to prevent contact I think you can make a 7" + 3-4" midrange sit and fire unobstructed. I do believe that you would have to do a bit of work to get the midrange to sit a little bit on top of the 7" frame (stacked for lack of a better word, or spaced somehow while maintaining a seal).
G'luck bro, I have a pic in my vette photos I believe that shows the door mount in mine.
Fej
fej is offline   Reply With Quote
Old 03-08-2007, 03:46 PM   #3
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
i am planning on angling the woofer which may give me a bit of additional clearance for my tweet (it's a large format tweeter ~3" diam IIRC). that may help you a bit too.
i'm going to be building my pods like you would a sub box baffle...speaker rings and fiberglass.
scott_fx is offline   Reply With Quote
Old 03-08-2007, 03:50 PM   #4
leolufse
CF Senior Member
leolufse's Avatar
Send a message via AIM to leolufse
Here are a couple of pics. Thats a 6.5" JL for size reference.
leolufse is offline   Reply With Quote
Old 03-08-2007, 04:16 PM   #5
Kale
CF Senior Member
Kale's Avatar
Fej, How do you like that tn51 in your door pull?
Mine drives me insane from reflections and the imaging is bad :/
Which is actually the biggest motivation for me to do my whole system over.
Th tn51 sounds pretty amazing up on the pillar, about halfway up though.
I see what you're saying... I think 25% blockage shouldn't be a huge problem... I'd be better off with the midrange blockign some of the midwoofer... like a dish hanging down over the mid. I'll have to do some glassing for sure
Old 03-08-2007, 04:24 PM   #6
scott_fx
CF Senior Member
scott_fx's Avatar
did you ever see penta's install with the tweet below the woofer angled up? you may be able to install the complete set in the stock locations if you do that
Old 03-08-2007, 04:28 PM   #7
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
Quote:
penta's install....please..... I'm the one who copied it from cdt duhh
but seriously its something you can try, the tweeter doesnt block the 6.5's at all. its as easy as just screwing the tweeter with the mounting screws of the 6.5 or whatever you will be using.
DPG is offline   Reply With Quote
Old 03-08-2007, 04:38 PM   #8
scott_fx
CF Senior Member
scott_fx's Avatar
lol...woops, sorry about that... you two are so 'buddy buddy' i mix you up all the time.
isnt this the 2nd time i've screwed you out of getting credit on something you've done?
Old 03-08-2007, 04:45 PM   #9
pentavolvo
Supporting Vendor
Cruise-In IX Veteran
pentavolvo's Avatar
buddy buddy whoa whoa, i might be buddy buddy with his gf but not him haha. That was 100% daves idea actually i personally would have never thought of it,.
pentavolvo is offline   Reply With Quote
Old 03-08-2007, 05:09 PM   #10
Kale
CF Senior Member
Kale's Avatar
The tweeter is not going in the doors. Just the 6.5 and 4
Old 03-08-2007, 05:37 PM   #11
TheRadioFlyer
Supporting Vendor
St. Jude Donor '08
1997 Chevrolet Corvette
TheRadioFlyer's Avatar
If you build an angled mount, you can avoid blockage alltogether:
here's how i did mine:
as you can see from the second pic, there's just enough room to put a small midrange in the lower-rear area if you used a spacer (aka speaker ring) preferably using a few rings sanded down to make an angled mount:
like so:
I used a belt sander to get that into this:
TheRadioFlyer is offline   Reply With Quote
Old 03-08-2007, 05:58 PM   #12
leolufse
CF Senior Member
leolufse's Avatar
Here is another idea that keeps the mid bass, mid range, and tweet close together (w/out building a complicated mount). Imaging is good unless you have a passenger
Old 03-08-2007, 06:25 PM   #13
scott_fx
CF Senior Member
scott_fx's Avatar
i wonder if you could fit the 3" to the right of where the tweeter is in this picture:
looks like that may be open enough not to be blocked....
Old 03-08-2007, 07:34 PM   #14
fej
CF Senior Member
fej's Avatar
Being with a 3 way, the midbass is less directional in those ranges, a combination of what Radio did with his with the angled midbass mount, albeit a fair amount less, which would allow you to get a bit lower in its position, coupled with a similar mount (probably made of fiberglass) to mount the midrange lower and closer to the midbass, or overlapping like I mentioned earlier, should give you the room to keep it unblocked. As soon as I motivate and stop messing with other projects, I am going to attempt something like I describe in mine to get the midrange a better path through the grill and slightly better imaging as my stage is somewhat low IMO. Even if you get it clean I would probably throw a little ensolite on the back of the panel to keep reflections down.
As for the tweets, I am pretty unhappy with their current location and off axis performance. Hell I need to get up that way and have you take a listen to the LPG's I have for your a pillar location. The only problem with them is they are 8ohms and throw a wrench in your passive crossover plans. Hell you want those things over 5khz if you have them on the pillars anyway. I'm going autocrossing this weekend but shoot me your number via pm and I will see when I can get up that way and we can mess around with some versions of your install.
Fej
Old 03-08-2007, 08:23 PM   #15
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
That's ok Scott, I'll remember that if I ever meet you.
Looks like radioflyers may be the best solution where you have the greatest flexibility.
Old 03-09-2007, 12:34 PM   #16
Kale
CF Senior Member
Kale's Avatar
Some great input in this thread.
Now I just have to decide... 2 way dyns.. or the CDT es set with HD woofer.
They have a previous model 8" mid 1" tweet set on woofersetc
the moderm dyn 3 way system is 3x thecost of the cdt set i put together.
biggest concern with dyn is the 2200hz xover point... I'm not sure if thats good or bad when the tweets will be in the A pillars.
Old 03-09-2007, 01:58 PM   #17
fej
CF Senior Member
fej's Avatar
2200hz is too low for A pillars ... you will run in to too many reflection issues with your vocals that will not be tameable with eq/ta/phase.
A very high percent of succesful A pillar installs start with a crossover point at 5k or higher. With large format tweets and very careful aiming you can get away with lower than 5k, but of the cars I have heard below 5k only 1 car sounded good, and that was at 3khz I believe using the "genesis" spec scan speak 2904/7000 tweet ($800 a pair). It was very, very good, and whats scary is it was untuned; no eq, no time alignment.
People far more knowledgeable than I can speak on the topic (namely werewolf) from diymobileaudio, or elitecaraudio. Lots of threads about it over there.
Hell at the end of the day you can do whatever the hell you want to do speaker placement wise and crossover wise, just make it sound good to you.
Fej
Old 03-09-2007, 03:08 PM   #18
Kale
CF Senior Member
Kale's Avatar
Ok, I think I'll START with the dyn 8" 2 way set.
Onec I have the fab skills to add the 3" dome mid, I'll do that, and start running a 3 way active...
Or just go with System 360 now... I wish it wasn't $900
Old 03-09-2007, 03:24 PM   #19
scott_fx
CF Senior Member
scott_fx's Avatar
very nice. as soon as i heard the dyn's in a system i went out and purchased some md130's for my setup. such a sweet warm sound to them!
Old 03-09-2007, 03:28 PM   #20
Kale
CF Senior Member
Kale's Avatar
I am going to blow my budget
Quote:
The Esotec MD 142 is housed in a compact self-contained enclosure with a vented pole piece and damped rear chamber.
Self contained. I could mount this thing suspended in front of the midwoofer. Or in that corner posted earlier in this thread.
The cheapest Ive found this set is $1399 though. Woofersetc has the OLDmodel for $899.
Reload this Page Mid blockage in door mount three ways? c5
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
