Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-12-2007, 10:42 PM   #1
A.J.C
CF Senior Member
A.J.C's Avatar
Send a message via AIM to A.J.C Send a message via Skype™ to A.J.C
Default Need help: Preamp out grounds went bad.
I have a Pioneer HU. I recently got a ground loop problem. The speakers had a wine that went with the rpms of the engine. I narrowed it down to the preamp outputs. If I touch a ground wire to the preamp rca ring, the noise completely goes away. I have heard pioneers are notorious for this problem.
My question is: What is the best way to fix this? Should i take the radio apart to fix it or solder a small wire to each ring and connect it to a ground?
Here is a picture of the back of my HU:
A.J.C is offline   Reply With Quote
Old 02-12-2007, 10:43 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
solder a small wire to each ground and connect to ground is the easiest way to do it and it works
pentavolvo is offline   Reply With Quote
Old 02-12-2007, 10:45 PM   #3
A.J.C
CF Senior Member
A.J.C's Avatar
Quote:
Thanks for the quick response. Thats what I'll do.
Old 02-13-2007, 10:58 AM   #4
Fasthotrod
CF Senior Member
Fasthotrod's Avatar
UnderRADAR
Send a message via AIM to Fasthotrod
Default I hate to ask...
I hate to ask such an obvious question... but I assume your HU is properly grounded? By that, I mean the HU chassis... not just the black wire in the HU wiring harness.
Can you use an ohm meter and 'ring out' the chassis ground and RCA ground on the HU? I'd check multiple points... one being the small screw between the RCA jacks. It might be as simple as making a small jumper between that screw and the HU chassis ground... followed to a hard ground to your car.
Just my two cents.
Mark
Fasthotrod is offline   Reply With Quote
Old 02-13-2007, 04:18 PM   #5
pentavolvo
CF Senior Member
pentavolvo's Avatar
preouts are known for blowing grounds on pioneers radios
Reload this Page Need help: Preamp out grounds went bad.
Tags
bad, hu, pioneer, preamps
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
