Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-01-2001, 04:37 PM   #1
alman
CF Senior Member
Default Need help with installation???
How hard is it to install a bazooka tube in a 96 vette? Could anyone give me some instuctions on how to do it.
alman is offline   Reply With Quote
Old 10-01-2001, 06:00 PM   #2
juthro75
Junior Member
Send a message via AIM to juthro75
Default Re: Need help with installation??? (alman)
this goes for just about anything. if tha tube has a built in amp, then run some 8 guage wire from the battery, to the amp. connect this wire directly to the battery, putting at least a 30 amp fuse within 18 inches of the battery terminal. find a hole in the firewall, or make one, and run the wire along the threashold, or under the carpet. then tap into your speaker wires somewhere and run those back to the tube. use 12-16 guage wire. when you buy the tube, i think they come with instructions that'll take you from there. any q's im me or send me an e-mail: theyleftme@poop.com
aim: junebugg187 good luck!
juthro75 is offline   Reply With Quote
Old 10-02-2001, 12:17 AM   #3
92TripleBlack
CF Senior Member
92TripleBlack's Avatar
Default Re: Need help with installation??? (juthro75)
Very easy, good basic upgrade. You can keep it later if you want to replace the rest of the system. Make sure your fuse is in the engine compartment. Distance from the battery isn't as critical but remember if you have an accident and the wire is broken it will be live up to the fuse so make it as close to the battery as is practical. Mine is about a foot away. You can splice to the speaker wires in the rear of the car. If you run into problems, let us know and we'll talk you through.
92TripleBlack. :cheers: :smash:
92TripleBlack is offline   Reply With Quote
Old 10-02-2001, 12:47 AM   #4
alman
CF Senior Member
Default Re: Need help with installation??? (92TripleBlack)
Thanks for the replies so far, yes it is the amplified tube. I want a little more bass but didn't want to replace the whole system right now so i figured this would be the best way to go. I have one question where is there a good ground in the trunk area? I have not received the bazooka tube yet but i want to prepare so when i receive it i will be ready to install it.
[Modified by alman, 10:48 PM 10/1/2001]
[Modified by alman, 10:49 PM 10/1/2001]
Old 10-02-2001, 01:09 AM   #5
92TripleBlack
CF Senior Member
I have mine straight to the frame. You could go out the cockpit throught the same hole they run the antenna wire and down to the ground just behind the back wheel on the frame. Best place to ground if you don't have to go to far.
92TripleBlack
Old 10-06-2001, 01:28 PM   #6
alman
CF Senior Member
I just received the bazooka tube today and it came with no instructions :eek: What should i hook up the remote wire to :confused: Also do i splice the high level inputs into the positive speaker wires?
Old 10-07-2001, 07:13 PM   #7
alman
CF Senior Member
Anyone :confused:
Old 10-07-2001, 07:20 PM   #8
92TripleBlack
CF Senior Member
Hook the remote wire to an ignition line. If you can't find one in the back, use the pink wire behind the sterio. There will be two pink wires, one will be ignition, the other is antenna. Check the wire with a meter. If you don't have one or you don't know how to get at the wire let me know. The inputs should be spliced into the speaker inputs in the back. Look for the speaker wires, two on each speaker. These are the ones you want. The darker colors are the negatives.
92TripleBlack
Reload this Page Need help with installation???
Tags
junebugg187
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Desperately need help with rebuilt engine. vethead C3 Tech/Performance 16 01-12-2004 01:58 AM
Need help with LG install!!! C5LOU C5 Tech 33 12-29-2003 10:15 PM
Need help with FX3 "service ride controll" light and codes. 95wht6spd C4 Tech/Performance 43 04-15-2003 07:57 AM
Need Help with LPE / Magnuson Install Speedline Vette C5 Forced Induction/Nitrous 14 01-24-2003 05:30 PM
Need Help with Exhaust Mod. in Houston FAST AG Southwest 28 01-23-2003 05:05 PM
Need Help With Finishing Installation....Please Help! USMUSCL C5 Tech 17 10-30-2002 07:15 PM
Need help with coil. Aaron-74 C3 Tech/Performance 23 09-06-2002 01:17 AM
Need help with questions about doing a lower thermostat mod... Tiger Shark C5 Tech 14 08-09-2001 04:22 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
