| Audio/Electronics Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette |
01-09-2007, 02:32 AM
CF Member
Any way to have my Moto Bluetooth mute the amp? 05w/Nav
I have installed a Motorola bluetooth system in my car. One of the wires from that unit is a "mute" wire.
Is there any way to use that wire to mute the amp?
I have a 2005 Bose/Nav
01-09-2007, 02:55 AM
CF Senior Member
Cruise-In IX Veteran
with a relay it should be doable, is it a 12 volt+ signal or a ground signal it gives out
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
