Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-01-2001, 06:02 AM   #1
Kale
CF Senior Member
Kale's Avatar
Default c4 box ideas, what do you think?
volume for BOTH 10" subs is 1.4 cubic feet.. probably not enough.
If I got really creative with the box design, and removed the doors and added "pockets" in the box.. i would have 1.9 cubic feet. I wonder if that would make it sound odd?
Minimum enclosure for the subs is .60, and max is 1.2 each, so I don't know how that comes into play.
Any ideas? I'm brainstorming before I begin to build this thing.
I'm looking at Focal Polykevlar 165K2 speakers for the front, powered at 80watts each.
Im probably going to power the subs at 250watts each or so, depending on what amps I can find.
I don't think I'll have any rear fill.
[Modified by Smash, 3:59 AM 10/1/2001]
Kale is offline   Reply With Quote
Old 10-01-2001, 06:05 PM   #2
juthro75
Junior Member
Send a message via AIM to juthro75
Default Re: c4 box ideas, what do you think? (Smash)
if the enclosure range is .60 to 1.2, anything around 8.0-1.0 will be fine. the smaller the box, the tighter and punchier the bass. larger will be boomier bass. so i think that you'll get away with a 1.4 cu. ft. box. just put some polyfill in there, and it'll be fine. those focals up front should sound mighty fine, and i woudn't go with rear fill either. also, if you mount the subs inverted, then the box will seem bigger to the subs, because the magnet won't be takin up that space. just wire them backwards and they'll sound the same.
juthro75 is offline   Reply With Quote
Old 10-01-2001, 06:12 PM   #3
Kale
CF Senior Member
Kale's Avatar
Default Re: c4 box ideas, what do you think? (juthro75)
mounted inverted??
hmn.. i have some REAL fine 4" speakers ill probably put in the back just for SOME fill, I'm sure i can mount them next to the sub.. or somewhere.
Old 10-02-2001, 12:13 AM   #4
92TripleBlack
CF Senior Member
92TripleBlack's Avatar
See my comments in Gonzos post.
92TripleBlack :cheers:
92TripleBlack is offline   Reply With Quote
Old 10-02-2001, 12:18 AM   #5
Kale
CF Senior Member
Kale's Avatar
Default Re: c4 box ideas, what do you think? (92TripleBlack)
check this out
Old 10-11-2001, 11:08 PM   #6
gcrouse
CF Senior Member
gcrouse's Avatar
Are you sure you need 2 of those things? I have a single JL 10W0 in my full-size van that can leave the ears ringing!
That being said, have you checked out the space in R storage compartment; it's approx 1 cu ft. Could part of your box drop down in there and use some of that volume? You really need .75 - 1.0 cu ft per 10" sub, and only if Vas is small enough; many need 1.5 - 2.5.
I thought about cutting MDF and gluing together an enclosure from the inside; then thought about fibreglassing it from the outside (under the car). In the end I've decided that enclosure wall flex is not such an awful thing- if it's OUTSIDE the listening environment. So I'm lining the inside walls with a dynamat-like substance, dumping in 2 lbs of acousti-stuff, and bolting a thick baffle across the whole area where the compartment doors were. I'll know how it sounds in a few days; and if needed I can always go back and build up those walls.
gcrouse is offline   Reply With Quote
Reload this Page c4 box ideas, what do you think?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
t56 questions, Fabricators come in!! 4bblC4 C4 Tech/Performance 81 05-27-2005 10:08 AM
Power seat not operating, stuck in BAD position PLEASE HELP robertpel9 C5 Tech 17 07-03-2004 01:10 AM
Single turbo ideas........ Phil97SVT C5 Forced Induction/Nitrous 12 11-15-2003 06:18 PM
Need ideas for a stealthy sub in a C4 84FromHell Audio/Electronics 17 01-14-2003 02:59 AM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
