Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-07-2007, 08:48 PM   #1
Gixster
CF Senior Member
Gixster's Avatar
Send a message via AIM to Gixster
Default Is this a reasonable setup?
I've decided to upgrade the stereo finally. When I got the car, there was already a Kenwood KDC-6011 installed, but it is still running stock speakers. I bought a cable to allow my iPod to play through it, but I haven't hooked it up yet.
I think I'd rather change head units in the process of the upgrade so I can control the iPod through the deck, and also have XM built in instead of having my Roady sitting in the console.
So, to that end, here's what I've come up with after perusing the FAQ and every page of this forum. Suggestions and comments are greatly appreciated. I'm interested in a stealth install, so all components will be hidden behind the factory grill covers, and I think I might also built a false floor in the rear similar to one I've found already here. This is all going in my '94 Coupe.
Head Unit: Alpine CDA-9857
Front Speakers: Infiniti Reference 6010cs 6-1/2” components w/ crossovers
Rear Speakers: 8W3v2-D4 8” subs
Amp: Rockford Fosgate Punch P450.4 4-channel car amplifier
60 watts RMS x 4
__________________
Tracy
'94 Torch Red 6-speed Coupe
Gixster is offline   Reply With Quote
Old 01-07-2007, 09:14 PM   #2
fej
CF Senior Member
fej's Avatar
Plan to bridge the rear 2 channels for the 8's wiring each coil in series and then the 2 in parallel for a 4 ohm load? Wiring them in normal 2 ohm load could net you around the same watts but place moe strain on the amp.
Otherwise looks pretty solid, one of the things that the new alpines do well is their ipod integration, may be worth the wait of a month or so to see what the 07 line brings feature/reliability wise.
Fej
fej is offline   Reply With Quote
Old 01-07-2007, 09:29 PM   #3
Gixster
CF Senior Member
Gixster's Avatar
Quote:
Originally Posted by fej View Post
Plan to bridge the rear 2 channels for the 8's wirinhg each coil in series and then the 2 in parallel for a 4 ohm load?
You lost me a little bit. Are you saying that it will be better to wire the 8s in a series and then parallel? Or just one or the other? I'm reading now about series and parallel wiring, but I'm not sure I understand exactly what you're telling me I should do.
Sorry, a bit of a stereo noob when it comes to the ins and outs of some of this stuff.
eta: As for the amp, should I use it to drive only the rear 8s, or connect it to the fronts w/ the crossovers also?
Old 01-07-2007, 10:22 PM   #4
fej
CF Senior Member
fej's Avatar
Connect channels 1/2 to your front components.
Bridge channels 3/4 to your 2 8's. Wire the 2 coils on each 8 in series initially (so 4+4=8 ohms per speaker) and then join the 2 drivers in parallel (8 & 8=4 ohms) and connect that lead to your amp channels 3/4 bridged (directions should be given in the manual or even on the amp itself)
Hope that helps, from a power/efficiency standpoint that is your best wiring option IMO.
Fej
Old 01-07-2007, 10:36 PM   #5
Gixster
CF Senior Member
Gixster's Avatar
Thanks for the reply. Once I get the equipment and begin to get some fabrication work done, I'll probably sketch up a wiring schematic to make sure I've got it right and post that to make sure it's correct.
Thanks again!
Tracy
Old 01-07-2007, 10:59 PM   #6
Kale
CF Senior Member
Kale's Avatar
Don't buy the 9857. It has none of the features that make alpine good. Look at another brand. The pioneer 7800 is a MUCH better alternative - I love mine.
Kale is offline   Reply With Quote
Old 01-08-2007, 01:54 AM   #7
JAMIROBri
CF Senior Member
Send a message via AIM to JAMIROBri
Quote:
Does this Pioneer unit have Ipod control? I have the Pioneer 5700DVD and the Ipod control is terrible.
JAMIROBri is offline   Reply With Quote
Old 01-08-2007, 02:41 AM   #8
Kale
CF Senior Member
Kale's Avatar
Quote:
it has a joystick on it, which works pretty much just like the click wheel on the ipod.
for example, if I wanted to pick a song,
List > rotate knob to Artist, push it right > rotate knob to album, push right, rotate knob to song, push right.
this unit doesnt have a lot of buttons - so the remote is very handy.
Old 01-10-2007, 04:39 PM   #9
Gixster
CF Senior Member
Gixster's Avatar
What's missing from the Alpine?
Also, what's the general concensus on Polk Audio speakers? A friend of mine has components and subs in his car and they sound great, so I was kicking around the idea of using Polks instead.
Thanks again!
Old 01-10-2007, 05:01 PM   #10
jashearer
CF Senior Member
jashearer's Avatar
Thanks again!
I have the Polk Momo 6.5s which I bought online for fairly cheap and they rock.
I also have the Alpine 9857. While I am dissapointed that it doesn't have the crossovers that some of my previous alpine's have had, I really like the display and especially the iPod functionality...
Luckily my amp has infinately variable crossovers, so I am just using them to set up my sound stage.
Jay
jashearer is offline   Reply With Quote
Old 01-10-2007, 07:54 PM   #11
Kale
CF Senior Member
Kale's Avatar
Thanks again!
Everything but volume control, bass, and trebel levels.
No real EQ, no crossover settings (uber useful) no adjustable button color, worse, less legible screen than previous years.
It's the Kia with manual windows and 14" tires of the car stereo world.
Polk speakers are very good for the price. I'd go with Polk or Infinity for my sub $100 choice. Both are easy to find on a sound wall, and you can a/b them.
Reload this Page Is this a reasonable setup?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Steal this 99 6spd vert...with Supercharger TANGLVR C5 Corvettes for Sale 34 07-23-2005 09:21 AM
LPE announces a new engine pkg: N/A 427 for under $20K!!!!!!! Ed@Lingenfelter C5 Tech 91 10-13-2003 12:36 PM
Missing Engine Vacuum, does this sound reasonable... dgoodhue C4 Tech/Performance 11 04-02-2003 08:54 PM
C1 Rear End..... Is this right? stouro C1 & C2 Corvettes 12 03-06-2003 10:00 AM
Who's interested in a Single Turbo System for the C5/Z06 Cerra Racing C5 Forced Induction/Nitrous 78 08-14-2002 01:28 PM
MMS 388 engine down for the third time....don't know what it is this time! GTP C5 Tech 200 06-05-2002 01:29 AM
I bought a Giovanni style 6-link IRS kit. Looking for setup info on it. lone73 C3 Tech/Performance 66 09-24-2001 12:11 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
