does anyone know which factory color pin-out (non-bose, c6) is the ignition power source, so i can tap in for my remote wire for my amp.
There's not a switched power wire in the radio harness. The radio is turned on & off by the car via the serial data bus (that's how RAP works) so the +12 you'd find in the harness is always hot.
I ran a wire down into the passenger footwell and tapped into a fuse there. I used the wiper circuit, works like a charm. You can either just put a wire on the fuse or grab an add-a-circuit at a parts store and it it in that way.
u sure u hooked it up right cause the whipers should shut off with the car meaning the amp will... otherwise get a voltmeter and start checkin other fuses
