Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-30-2001, 02:32 PM   #1
The Dingo
CF Senior Member
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11
The Dingo's Avatar
Default Basic C4 Bose system replacement Q (first of many)
At the moment I am planning to soon replace my Bose with an Alpine deck, changer and an amp to run the current Bose speakers which I will use until my budget allows a good set of components and a sub (or two).
I just read elsewhere that you cannot run the Bose speakers with an aftermarket setup without the expensive adapters. Is this true or could I wire the amp up directly to the Bose speakers without the adapter?
TIA
The Dingo is offline   Reply With Quote
Old 09-30-2001, 03:02 PM   #2
Kale
CF Senior Member
Kale's Avatar
Default Re: Basic C4 Bose system replacement Q (Red 90 L98 Coupe)
you need the adapters. Even with the adaptors, they sound bad.
Kale is offline   Reply With Quote
Old 09-30-2001, 05:26 PM   #3
XTRME 94
CF Senior Member
XTRME 94's Avatar
Send a message via AIM to XTRME 94 Send a message via MSN to XTRME 94 Send a message via Yahoo to XTRME 94
Default Re: Basic C4 Bose system replacement Q (Smash)
BOSE speakers have a really wierd ohm rating. No were near standard. :nonod:
XTRME 94 is offline   Reply With Quote
Old 09-30-2001, 10:33 PM   #4
Dave84/76
CF Senior Member
Dave84/76's Avatar
The adapters for the Bose system allow you to connect an aftermarket source to the factory amps. This will not help you to use an aftermarket amp. The factory Bose speakers have a 1 ohm voice coil, and most aftermarket amps are not stable at 1ohm. Sony makes a 4-channel amp that is 1 ohm stable, but that would not be my choice. You would be better off replacing the speakers when you install the head unit and changer, and hold off on the amp until your budget allows.
Dave84/76 is offline   Reply With Quote
Old 10-02-2001, 12:50 AM   #5
The Dingo
CF Senior Member
The Dingo's Avatar
Doh! Looks like I have to review my plan of attack.
Thanks for the replies guys.
Reload this Page Basic C4 Bose system replacement Q (first of many)
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
