Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-09-2006, 04:34 PM   #1
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Default [C4] rear mount woofer update
So I have been working on sealing the OEM rear enclosures in my vette.. well it was mId 30s (F) today so I thought I would see how they sounded now.
I took my a/d/s PS5 amp to test it, well apparently the remote input on the a/d/s is asking for more current then the Nak headunit can handle and the amp would not turn on. Not a show stopper since I could run it through a relay but I was unable to test it in the car (but I know it does work)
Anyway I hooked up my eD NINe.2 I think the gain was set at 20v (I did not reset it from the last time). Well they sound AMAZING!!! nice and tight, clean the way they should..
I am thnking now that the NINe.2x might be a bit of OVERKILL for the 8s. I do not have the fronts connected yet as the rear of the car is still in pieces.. So I am not sure what to do.. I am guessing that the eD amps will work fine, but not so sure if the NINe.2x will be too much.
SO at least I am making progess..
I really wanted to see how the PS5 sounded, but I am not going to sweat it.
Now I need to pull the doors apart a bit to remove the passives I have tucked in there (or bypass them to use my CDT X-overs)
-=Jeff=- is offline   Reply With Quote
Old 12-09-2006, 07:24 PM   #2
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
if you are just curious about testing the amp you can just place a 'jumper' wire from the constant 12v at the amp to the acc turn on lead. that'll power it up and let you test how it sounds.
scott_fx is offline   Reply With Quote
Old 12-09-2006, 08:58 PM   #3
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Quote:
Yeah I know.. but it was hard enought stuffing the 8ga wire itn he contact for the PS5.. LOL
not a big deal, besides 2 PS5s are the same size as one NINe.2
Old 12-13-2006, 09:56 AM   #4
AGENT 86
CF Senior Member
AGENT 86's Avatar
Glad to hear you finally got those 8's to work for you.
__________________
AGENT 86 is offline   Reply With Quote
Old 12-13-2006, 05:25 PM   #5
Eakster
CF Senior Member
Eakster's Avatar
do you have any pics?
Still debating here whether to go for 2 8" subs or a single 10 or 12 in my 96 C4 (Delco)
How much work to seal the stock rear units?
Eakster is offline   Reply With Quote
Old 12-13-2006, 06:18 PM   #6
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Not any of the sealing, but here is one with the woofer in place:
__________________
-=Jeff=-
1990 ZR-1
NCM Lifetime member
My Website
Member: Fox Valley Corvette Club
1989 Custom Coupe (SOLD)
Old 12-13-2006, 08:45 PM   #7
AGENT 86
CF Senior Member
AGENT 86's Avatar
Here are a few pics from my install. The rear enclosure is a sealed unit. Mine had factory insulation, others seem to have no insulation. I sealed mine with butyl tape.
__________________
Old 12-13-2006, 09:44 PM   #8
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Quote:
Not completely.. it is 2 halves glue together.. Mine was not completely sealed for some reason.. but it is now
__________________
-=Jeff=-
1990 ZR-1
NCM Lifetime member
My Website
Reload this Page [C4] rear mount woofer update
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Audio FAQ bogus Audio/Electronics 49 01-31-2012 04:41 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
