Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-08-2006, 11:32 PM   #1
Iceman203
CF Senior Member
Send a message via AIM to Iceman203
Default Need advice on setup
Just got all my pieces together for my system except the sub, sub box, and amp. Didn't pay too much attention but now I am a little concerned about my amp over powering my speakers. What do you guys think? Its not by much except on the 5 1/4". I was thinking about putting the dash speaker on the same channels as the rears but that would not allow the fader to work, eliminating the surround sound. Here is the whole system:
Headunit: Panasonic CQ-VD6503U http://www.crutchfield.com/S-5xcSOwx...sp?i=133VD6503
Amp: Infinity Reference 7541a 111 RMSx4 channels http://www.crutchfield.com/S-5xcSOwx...1a&i=108R7541A
Front Speakers: Infinity Kappa 60.7cs 90RMS http://www.crutchfield.com/S-5xcSOwx...7cs&i=108607CS
Rear Speakers: Infinity Kappa 52.7i 55RMS http://www.crutchfield.com/S-5xcSOwx...2E7i&i=108527I
Dash Speaker: Infinity Kappa 32.7cf 35RMS http://www.crutchfield.com/S-5xcSOwx...7cf&i=108327CF
Iceman203 is offline   Reply With Quote
Old 12-09-2006, 12:55 AM   #2
BlackMark
CF Senior Member
Support Corvetteforum!
BlackMark's Avatar
I'm using the exact front and rear speakers as you,with an Infinity 104.7W dual voice cone 10" sub in the back.I decided to eliminate the dash speaker,and use that space for my nav and XM antennas.I'm using two amps-an Audiobahn A4004V 4-channel for the cabin speakers,and an Audiobahn A6005DN mono for the sub.They have built in cooling fans and plenty of adjustment for crossover points for low and high pass filtering plus bass boost.Pioneer Avic D2 for the hu/nav.I'm waiting for the sub box and amp rack(which should have shipped from Tennesee this week)before getting started on the install.Everything else is piled up and ready.
BlackMark is offline   Reply With Quote
Old 12-09-2006, 01:01 AM   #3
Iceman203
CF Senior Member
Quote:
I am just worried about the kappas being 2ohms and the amp pushing out 139 watts RMS @2ohms and the 5 1/4" kappas only rated at 55 watts RMS. I was told by crutchfields that I would be ok if I turned the gain down almost all the way to the rear. Still makes me worry though.
Old 12-09-2006, 06:28 AM   #4
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
properly setting the gains you should be fine
pentavolvo is offline   Reply With Quote
Old 12-09-2006, 12:32 PM   #5
BlackMark
CF Senior Member
BlackMark's Avatar
The sensitivity of thre Kappas is such that it doesn't take much power to light 'em up.it is something like 95db,and meant to sound good even with a low output factory amp and hu.
Old 12-10-2006, 08:13 PM   #6
Iceman203
CF Senior Member
But my problem is I have too much
Old 12-10-2006, 08:16 PM   #7
pentavolvo
CF Senior Member
pentavolvo's Avatar
you will be fine trust me
Old 12-11-2006, 02:39 AM   #8
BlackMark
CF Senior Member
BlackMark's Avatar
Peak power on the 5.25 Kappas@ 2ohms is 165 watts.You won't be pushing them that hard with your current amp.
Old 12-12-2006, 01:40 AM   #9
Iceman203
CF Senior Member
That is peak. My amp pushes out 139RMS @2 ohms continuous. RMS rating on the 5 1/4" kappas is 55watts RMS. I could turn the gain down half way on my amp and still overpower the speakers technically. Unless I am missing something.
Old 12-13-2006, 09:40 PM   #10
Speeed-Racer
CF Senior Member
Speeed-Racer's Avatar
Turn the gain on the amp all the way down. Turn the head unit (HU) up to 75% or so and then the amp gain up until it starts to distort, then back down a touch. If the amp gain is only 25%, all the better. It's called "head room" and will give you a better sound quality (sq). It will also give you the most "swing" on the HU volume control, meaning a little volume won't blow you away, or a lot of volume and it still isn't loud enough. That's a little simplistic, but there you have it.
Speed
Speeed-Racer is offline   Reply With Quote
Old 12-13-2006, 10:09 PM   #11
Iceman203
CF Senior Member
Quote:
Speed
THanks man
__________________
2007 Corvette C6 2LT Black/Cashmere Z51 Manual
Reload this Page Need advice on setup
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need advice on 1965 Convertible Mr D. C1 & C2 Corvettes 34 03-04-2005 06:30 PM
Need advice on my mods... Not sure what to do? Draven C4 Tech/Performance 23 11-05-2004 01:15 AM
Need Advice on 427 BB Build Up Mr D. C3 Tech/Performance 45 03-15-2004 11:03 PM
Need advice on modding 96LT4, zf6. MrCrowley C4 Tech/Performance 35 12-05-2002 11:41 AM
Need advice on H/C package bradfordjr C5 Tech 10 08-12-2002 11:26 AM
Need advice on my 1966 L72 project Mr D. C1 & C2 Corvettes 28 05-10-2002 11:21 AM
Need advice on purchase of new differential KorbenDallas C3 Tech/Performance 18 05-08-2002 12:39 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
