Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-14-2006, 10:35 PM   #1
jaxmike
CF Senior Member
Default C5 System ideas
My old stereo plan fell through, so I am starting over. I am thinking about running 8" subs and 3.5" speakers in the door panels. 5.25 in the back and maybe a set of tweeters in the doors or a plilars. 2 4 chanel amps.
What do you guys thionk.
jaxmike is offline   Reply With Quote
Old 11-14-2006, 10:51 PM   #2
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
are you suggesting a 3 way amped system or are you planning on just doing a bose speaker swap out?
scott_fx is offline   Reply With Quote
Old 11-14-2006, 11:11 PM   #3
jaxmike
CF Senior Member
I dont really know waht you mean by 3 way. I was thinking an amp (4 channel) to run the 8" subs in the doors and the 3.5 and a second amp to run the tweeters and the 5.25s. But I am an extreme novice so feel free to tell me I am crazy.
I have a Pioneer Premier 680mp HU. What would it be like if I just did the 8's, the 3.5's and the 5.25's off the HU, wouldnt that be kind of a upgrade but similar type system to oem ?
Old 11-14-2006, 11:23 PM   #4
scott_fx
CF Senior Member
scott_fx's Avatar
what you described is what we call an active 3 way system. not crazy but it's advanced. you have ultimate freedom over tuning and component selection but if your head unit doesn't have a great x-over then you'll need to get an active x-over. a few of us on here are doing that sort of setup. i have a hybrid 3-way system. 6.5" subs in the doors running off of one 2 chan amp and then the 4" and tweet running off a second 2 chan amp with a passive x-over. then i have a third amp for the sub in the trunk.
if you're a novice you may want to stick with a simpler set up. maybe a 2-way component system in front (6.5" and tweet) running off of two chans (one chan per side because you are going to use the passive x-over) and then bridge two chans and toss a sub in the rear.
if you ran all that off the h/u you would run into issues wiring it all up and the h/u just doesn't have the juice to power an 8".
Old 11-14-2006, 11:38 PM   #5
EG@EnglandGreen
Supporting Tuner
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Support Corvetteforum!
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ ____________ 281.464.2800
englandgreen.corp englandgreen
Send a message via ICQ to EG@EnglandGreen Send a message via AIM to EG@EnglandGreen
LOTS of great ideas here - http://forums.corvetteforum.com/show....php?t=1305774
EG
EG@EnglandGreen is offline   Reply With Quote
Old 11-15-2006, 07:41 AM   #6
jaxmike
CF Senior Member
Thanks Guys
E G thats where I saw your pics of those 8" you had in the doors. Maybe I should stick with the simplier system to start.
I noticed alot of you guys dont run rears but most of the shops I have been in say I need them for fill. Any tips on which way to go ?
Old 11-15-2006, 11:40 AM   #7
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
in a vette you really dont need them at all becuase you will barely ever hear them, especially if you have nice speakers in front. They say you need them because then they will say you should amp them and by time its done its another 2-300+ in there pocket
pentavolvo is offline   Reply With Quote
Old 11-15-2006, 01:12 PM   #8
scott_fx
CF Senior Member
scott_fx's Avatar
for the next few weeks drive around with your rear speakers off (fade knob) after you forget about not having rear speaker sound, you can will be able to figure out if you're a no rear speaker guy. you do have to give it time. we are so used to having rear fill that when it's gone we may think something is missing. When you are used to it then you will be able to appreciate the improved soundstage
Old 11-15-2006, 02:09 PM   #9
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Quote:
I tried that in my GTP (rear speakers off) the preparation for the last time I re-did the vette. In my GTP with the factory system, I needed the rear fill, there was something missing without it.
Now with the last system I put in my vette (currently being redone) I ditched the rear fill. It sounds great that way. so even though it may not sound right with the OEM, install the fronts and a sub then try it.. if you still don't like then add your rear fill
-=Jeff=- is online now   Reply With Quote
Old 11-15-2006, 02:25 PM   #10
scott_fx
CF Senior Member
scott_fx's Avatar
good advice jeff. it's always an easy add on. and you can just power them off the head unit if you decide to add them in the future.
Old 11-15-2006, 03:14 PM   #11
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
knewblewkorvette's Avatar
Quote:
I suggest a 6.5" componet systems up front with a single sub in back for a reallly nice set-up.
knewblewkorvette is offline   Reply With Quote
Reload this Page C5 System ideas
Tags
c5, corvette, ideas, subwoofer
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
LMAO - A MUST READ FOR THE DIE HARD C5'ers AC54ME C5 General 61 03-07-2005 08:42 PM
99 c5 M6 rejecting alternator transplant redrodxp C5 Tech 36 11-11-2004 07:55 PM
C5 system build...newbie to car audio needs your input. G 99 Audio/Electronics 9 12-03-2002 09:54 AM
Need ideas: where to mount toggle switch for electrical cutouts on my C5? gary brown C5 Tech 25 09-16-2002 04:21 AM
Halltech's TRIC Twin Turbo repaves the highway Halltech C5 Z06 Discussion 61 06-27-2002 05:51 AM
System ideas ... MrVegas Audio/Electronics 11 03-05-2002 12:01 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
