Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2006, 10:17 PM   #1
TGKx
CF Senior Member
Send a message via AIM to TGKx
Default Mounting Focal 165 K2P
I got my pair of Focal's today and was hoping someone who had installed theirs could please chime in.
I had 3/4" MDF mounting brackets cut that include holes for both the midrange and the tweeter. When mounting the bracket should I do it bare against the door frame, or should i dynomat and then bracket it over that?
Also, where did you put your crossovers? I was looking around the doors and the room looked questionable, I was thinking maybe putting them behind the seats.
Thanks for your help
TGKx is offline   Reply With Quote
Old 11-08-2006, 11:04 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
deadener will elimate any extra rattles
crossover is best not in the door, ive put em in the door and its a bitch
pentavolvo is offline   Reply With Quote
Old 11-08-2006, 11:09 PM   #3
TGKx
CF Senior Member
Okay where should I put them then?
Old 11-09-2006, 02:11 AM   #4
OSCS Ret
CF Senior Member
St. Jude Donor '07
OSCS Ret's Avatar
mine are under the passenger seat. out of sight, out of mind... yet easily accessable
OSCS Ret is offline   Reply With Quote
Old 11-09-2006, 02:24 AM   #5
fej
CF Senior Member
fej's Avatar
Mine are in the same place as jefe's .. but my amp is under that seat as well If you are comfortable enough .. or unconcerned enough with the tuning of your set up that you can set them and forget them .. or tune with the door panels off, then go with them in the doors, but I would look into another option (near amp location .. under passenger seat .. on back wall behind seat), it is worth the extra speaker wire.
G'luck
Fej
fej is offline   Reply With Quote
Old 11-09-2006, 11:33 AM   #6
TGKx
CF Senior Member
Quote:
G'luck
Fej
I did some looking last night and agree best place is behind seats on the wall, going to use heavy duty velcro to stick them on the carpet for easy access. How did you extend the wires of the tweeters? They came with wires soldered on already.
Old 11-09-2006, 03:14 PM   #7
Buddy A
CF Senior Member
Buddy A's Avatar
You can go to Lowe's ( or where ever) and go to the electrical area. They will have male and female disconnects that are made for different gauge wire. These will be crimped on the end of the wires. This will make it easy to connect the different gauge wires together. Also gives you a disconnect for when you need to remove the door panels in the future. This is what I did.
Buddy A is offline   Reply With Quote
Old 11-09-2006, 03:40 PM   #8
TGKx
CF Senior Member
Quote:
Thanks will give that a shot!
Reload this Page Mounting Focal 165 K2P
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
