Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2006, 09:04 AM   #1
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Default C4 rear OEM enclosures.. (and a small update)
are NOT completely sealed.
I spent some time on Saturday and Sunday Sealing them up. I am waiting for a couple things to show up and the time to work on it again. hopefully this will resolve some of my issues..
Then I need to decide which way to use the Amps.. I think the 2x will be a better fit for the 9kv.2s but will try both again.. the 9.2 and 9.2x for the rear..
I still need to decide how I am laying out the amps
-=Jeff=- is offline   Reply With Quote
Old 11-14-2006, 09:45 PM   #2
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
getting closer...
I mounted the woofer again.. sems like the gasket material I used it leaking on one side of the baffle.. I will try to seal it later this week..
when I push lightly on the woofer, you can here the air rush out of one side of the baffle
at least it is progress
Old 11-14-2006, 10:23 PM   #3
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
keep us posted
DPG is offline   Reply With Quote
Old 11-14-2006, 10:32 PM   #4
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Quote:
Originally Posted by DPG
keep us posted
one step forward.. three steps back.. sealling DID NOT work
The hardest spot to see, work on sealling is not sealed.. I am about to give up.. most of the spots are sealed except the 2 hardest spots.. not sure how I will get to them to try and seal them..
I was really hoping to put the 8s in the factory spots.. this really bites..
Old 11-14-2006, 10:52 PM   #5
Kale
CF Senior Member
Kale's Avatar
expanding foam?
Kale is offline   Reply With Quote
Old 11-14-2006, 10:53 PM   #6
wiz1500
CF Senior Member
wiz1500's Avatar
Send a message via AIM to wiz1500
Just a thought bro....Can you just make fiberglass enclosures for back there?????? Just pull out all the factory stuff and make pods..There may be less drama....Just a thought...
Keep up the good work...
wiz1500 is offline   Reply With Quote
Old 11-14-2006, 10:55 PM   #7
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
I could I guess, but i would have way too little enclosure size..
Kale,
I tried exanding foam on one side, I guess I could give it another shot though. it is in the back upper corners of the inside of the box.. almost impossible to get to.
Old 11-15-2006, 08:55 AM   #8
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
I thought about it a little last night.. I think I can get to the top side of the area I need to seal. I have a feeling that gravity being against me since I was working on the bottom side is causing some issues. I will try again and see how it goes
Old 11-15-2006, 12:12 PM   #9
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
keep at it bro.... your so close
Reload this Page C4 rear OEM enclosures.. (and a small update)
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
