Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-07-2006, 11:35 PM   #1
blackwithyellowta
CF Senior Member
blackwithyellowta's Avatar
Send a message via AIM to blackwithyellowta
Default Someone who can customize my radio bezel..
Yes, I need someone to cut my radio bezel in order to fit the avic-z1, because I dont have the balls to do it. I want to keep the zc unit where it is and keep the ash tray as well. It can be done because I have seen it. Who is up for it????
blackwithyellowta is offline   Reply With Quote
Old 11-08-2006, 12:46 AM   #2
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
The C5 has 1.5 din opening...the Z1 is a 2 din opening. So something has to give for the extra space to be aquired. Do you have a picture of this is install you speak of? Personally I have modified many bezels to fit dbl din units and larger and every one I have moved the ac unit.
EatRice is offline   Reply With Quote
Old 11-08-2006, 01:06 AM   #3
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
hey eatrice, there are a few of the members on here that have what he describes. usually it involves just cutting the divider bar and trimming the upper part of the radio surround
scott_fx is offline   Reply With Quote
Old 11-08-2006, 01:08 AM   #4
NVTHIS
CF Senior Member
NVTHIS's Avatar
Yeah, most of the ones I have seen have had the AC unit relocated to the ash tray area. I know there is one member here that still has everything in it's stock location, but he did have to have the piece under the radio notched to allow the avic Z1 to fit. Goodluck on your hunt, Brandon. I know someone out there can help you out in this area.
NVTHIS is offline   Reply With Quote
Old 11-08-2006, 02:10 AM   #5
EatRice
CF Senior Member
EatRice's Avatar
Quote:
Cool...I would like to pictures. Does it look like it belongs or like it a piece of cut plastic?
Old 11-08-2006, 02:18 AM   #6
mud flap
CF Senior Member
I came across this pict on one of the other topics, it appears it can be done.
Dave
mud flap is offline   Reply With Quote
Old 11-08-2006, 02:20 AM   #7
scott_fx
CF Senior Member
scott_fx's Avatar
depends... some look like cut plastic and i've seen a few that have been done where it looks close to factory. for the life of me i can't remember the member who has (imho) the best looking one. i just remember that he did do some remolding and the original piece he started with was pretty beat up.... maybe he'll step forward
Old 11-08-2006, 04:42 PM   #8
blackwithyellowta
CF Senior Member
there is on that looks really good, hopefully someone knows of him...still looking
Old 11-08-2006, 05:24 PM   #9
cjz06
CF Senior Member
cjz06's Avatar
PM sent
cjz06 is offline   Reply With Quote
Old 11-08-2006, 05:51 PM   #10
dmoran1845
CF Senior Member
dmoran1845's Avatar
I just put a z1 in my vette. I did not move the a/c unit. However, I did have to cut the bezel at the top and remove the piece between the radio and a/c unit. I am in the process of trying to make an addition to the bezel to clean up the look. When I get a chance, I will post some pictures.
dmoran1845 is offline   Reply With Quote
Old 11-08-2006, 07:43 PM   #11
Roc87
CF Senior Member
Roc87's Avatar
I think it's "C5KIDD" that will do the bezel mod.
Roc87 is online now   Reply With Quote
Old 11-09-2006, 01:49 AM   #12
spiral04
CF Senior Member
spiral04's Avatar
I just installed a double din Eclipse Avn5500 in my C5. I shaved the bar between the radio and A/C about half way and also trimmed the top just a hair so the unit can flip down. Once the stock head unit was removed, I had to trim out part of the bracket in the back to allow the radio to slide farther back. The unit is a very tight fit because of the A/C ducts behind the radio. I think most people drop the head units down because there is more room there. I wanted a stock look. I try and post pics soon!
spiral04 is offline   Reply With Quote
Old 11-09-2006, 01:59 AM   #13
blackwithyellowta
CF Senior Member
Thanks spiral, thats what im looking for.
Old 11-09-2006, 12:05 PM   #14
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
TheRadioFlyer97's Avatar
check here:
http://www.nationalcorvetteregistry....19&prevstart=0
TheRadioFlyer97 is offline   Reply With Quote
Old 11-09-2006, 01:20 PM   #15
spiral04
CF Senior Member
spiral04's Avatar
Quote:
Originally Posted by TheRadioFlyer
Where was this site about a month ago. Many threads have been looking for something like this for quite sometime. The only problems I see with this is (1) no pics of their work and (2) I was told to cut it properly, so it will as stock as possible, it would have to be matched up with the radio for exact fitment. I don't know anything though! Just my $.02
Old 11-10-2006, 01:15 AM   #16
0Audio Dave
Former Vendor
Audio Dave's Avatar
Location: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
Send a message via AIM to Audio Dave Send a message via Yahoo to Audio Dave
Actually, it just got added about a week ago, and pics should be up soon as soon as the mod is done. PM if you have any questions.
Hope this helps!!
Audio Dave is offline   Reply With Quote
Reload this Page Someone who can customize my radio bezel..
Tags
bezel, c5, corvette, customize, kidd, radio
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
