Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-12-2006, 03:13 PM   #1
Teddydog
CF Senior Member
Teddydog's Avatar
Default Dimmer connection for aftermarket HU
I'm THIS CLOSE to finishing up my complete install in my 96. I was looking at the wiring harness and adapter that I received with my HU (from Crutchfield). The radio reciever plug has 4 wires--switched power, constant power, antenna lead and ground. I was hoping to find a dimmer lead, too. Checking the wiring diagrams in the FSM, I found two dimmer candidates in the factory HU harness: one is labeled LCD and the other LED. Would either of these be correct to tap into for the new HU? Or should I just not bother with the dimmer? Thanks!
Rob
Teddydog is offline   Reply With Quote
Old 10-12-2006, 06:28 PM   #2
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
doesn't the dimmer just look for a +12v signal? if it does i think you can just tap into your headlight switch. when you turn on your lights, it'll show 12v and tell the h/u to dim....i think.
scott_fx is offline   Reply With Quote
Old 10-12-2006, 06:31 PM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
i agree with scott on this, so you could just those 2 wires with a voltmeter to see which one hits +12v when parking lights are turned on
pentavolvo is offline   Reply With Quote
Old 10-13-2006, 12:15 AM   #4
adown
CF Senior Member
Are you talking about being able to dim your h/u with your dash lights? I think that is covered in the FAQ. I believe it is a tan or cream color wire in the hvac connector.
adown is offline   Reply With Quote
Old 10-13-2006, 12:21 AM   #5
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
There are generally two different "light" wires in most cars. One is the illumination wire..it goes to 12v when the lights are turned on. The other is the dimmer wire. It goes 12v when the lights are turned on but it is controlled by a reostat. The dimmer wire is what should be used to illuminate the radio. You can catch it all over the dash area. Anywhere there is another light. I do believe it is tan or gray...as mentioned before. The best thing to do is test using a VOM. Turn your lights to full bright. Then with the VOM attached to the suspected wire dim the lights. The voltage will drop and then go to 0 volts if you turn off the lights. That is the wire you need.
EatRice is offline   Reply With Quote
Reload this Page Dimmer connection for aftermarket HU
Tags
aftermarket, c6, car, connection, corvette, dimmer, hu, light, stereo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
