Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-10-2006, 04:57 PM   #1
gr8erV8
Junior Member
Default Where to ground amp in 90 C4?
This is question 5 in the c4 audio FAQ.
I looked in the FAQ and couldn't find the answer-maybe I am blind though.
I would love to use the passnger seat bolt-but I can't tell if it is supplied ground by the harness or through the frame--anyone know? If it is through the harness then it will definitely be too small of a wire--I am using 4ga wire for ground.
If not with the seat bolt, where is a convenient place to ground that doesn't require a drilled hole in the floor pan and a bolt to the frame?
I'm at the tail end of an install in my 90 c4. I have 6x9's in the back, 5x7s up front, and a 10" sub in the storage compartment. Wish I went with 6.5's in the back and 5.25's up front. Too late now. Anyway they will be way better than blose. I made an amp rack to replace the storage compartment doors for two amps--a 4X150 and a 1X500 Everything is wired except amp ground.
gr8erV8 is offline   Reply With Quote
Old 10-10-2006, 06:54 PM   #2
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Seat bolt is fine.. I have mine grounded to the driverside seat bolt.. no problems
__________________
-=Jeff=-
1990 ZR-1
NCM Lifetime member
My Website
Member: Fox Valley Corvette Club
1989 Custom Coupe (SOLD)
-=Jeff=- is online now   Reply With Quote
Old 10-10-2006, 11:08 PM   #3
gr8erV8
Junior Member
Quote:
Thanks. BTW your install looks pretty nice!
Old 10-11-2006, 01:26 AM   #4
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Seatbelt bolts and/or the structure underneath. (In a vert there are seatbelt towers. I assume in the coupe the belts bolt to the roof hoop.)
Vis Croceus is offline   Reply With Quote
Old 10-11-2006, 11:51 PM   #5
adown
CF Senior Member
In my 88 I just went through the bottom of the car right to the frame.
adown is offline   Reply With Quote
Old 10-13-2006, 02:42 PM   #6
gr8erV8
Junior Member
Quote:
So the seatbelt bolt is grounded, but is the seat bolt?
Old 10-13-2006, 04:52 PM   #7
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
My install??? where did you see it.. I don't have many pictures of it
Old 10-13-2006, 04:52 PM   #8
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
YES I grounded to the Seat BOLT.. I did not ground to the seat belt
Old 10-14-2006, 04:35 AM   #9
bogus
CF Senior Member
Send a message via Yahoo to bogus
hm... I will double check the FAQ... thanks for the heads up!
I ran my ground right back to the battery.
bogus is offline   Reply With Quote
Old 10-14-2006, 02:25 PM   #10
gr8erV8
Junior Member
Bogus, Thanks for the update.
Jeff, I thought you had a few pictures up.
At any rate I cannot see where the seats are connected to anything but plastic. I must assume that they are grounded with a wire through the harness.
The seatbelt bolt is obviously right into the frame--it is just about 45 minutes worth of time harder to use than the seat bolts.
I know the c5 guys use the seat bolts, but maybe c4 guys shouldn't.
Because the seat is grounded your amp would maybe work fine for awhile, but ultimately you would be grounding your amp with something on the order of a 12ga wire. Maybe this is fine, amp wiring is ususally overkill anyway. But then why buy the fancy 4ga wire? Also, there is the very real chance of frying the seat ground wire.
Sorry for the long post--just summing up the topic.
Thanks to all who contributed!!
Old 10-14-2006, 03:45 PM   #11
bogus
CF Senior Member
I was always curious about how the seats were attached. But I think DOT requirements mean they must be secured to metal. What we are not seeing is perhaps a cross spar. The big washer thingy is simply reinforcment.
I ran mine back to the battery because I know that Vettes can be tough to deal with...
I updated the FAQ, too! Thanks for the heads up!!
Old 10-15-2006, 12:44 AM   #12
Teddydog
CF Senior Member
Teddydog's Avatar
I can answer this definitively...at least for my 96. I finished installing my equipment today, but have not reinstalled the seats yet. I screwed one nut down a seat bolt just far enough to make room for my ground ring and another nut. Worked great for my testing! Since the seat is not installed, the ground is ABSOLUTELY going through the bolt into the frame.
Rob
Teddydog is offline   Reply With Quote
Old 10-26-2006, 11:04 PM   #13
Vis Croceus
CF Senior Member
Since I have my car apart, I thought I'd add what I found.
In a 94 vert there are some factory ground screws that could be used:
- on the wall behind the passenger's seat (next to where the wires pass into the storage bin)
- on the wall behind the driver's seat (up near the seatbelt tower) - I think this ground is for the heated window, so it is probably not there on coupes or early verts.
- in the passenger footwell just in front of the door (visible if you remove the sill carpet)
Reload this Page Where to ground amp in 90 C4?
Tags
amp, c4, corvette, good, ground
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
