Quick And Easy CD Ripping For The Corvette-How to step by step
#41
My filename conversion program is done. I just need to test it. I will provide source for those who wish to inspect it.
I may add a burning utility to the program that allows you to select which songs you want to add to an CD. It will be easier than find/drag/drop/burn in windows, and way less overhead than iTunes or other programs. The interface won't be fancy, but will be very clear and easy to understand for the digitally challenged.
This will take me a couple days worth of lunch time programming. Maybe Monday next week it will be ready?
-DG
-DG
#43
Do any of the 06 Nav units have a problem playing MP3 disks? I tried a couple of MP3 CD-Rs that play fine in my 2003 Ranger, but they don't play in my 2006 vette.
I thought I read somewhere that 05s need a software update to play MP3s. What about 06?
#44
hey - i've got a fave. i heard this band recently. and i think someone cloned teh Yardbirds! anyways check out the Rave ups covering "what do you want?" man this guy can play! you could check in www.theraveups.com
#45
OK! I followed the edirections step by step and still came up with nothing.
I have an MP3 disc with 80 songs on it that I got from a friend and want to be able to play in my Vette.
I copied them to a folder on my Desktop.
Made sure all the titles had less than 32 characters.
Created 5 fiolders in "My Music" labeled a-e, 16 songs in each.
Dragged all of them to the Burner Disc Drive.
Burned them.
Wound up with only the first 15 songs and no info displayed on the screen.
Any ideas?
Burned them.
Any ideas?
#46
I have an MP3 disc with 80 songs on it that I got from a friend and want to be able to play in my Vette. I copied them to a folder on my Desktop. Made sure all the titles had less than 32 characters.
Burned them. Wound up with only the first 15 songs and no info displayed on the screen. Any ideas?
Or at least make sure that the original plays in your Vette.
Then make sure a copy that you make plays.
Maybe forget the folder idea. I just put all my files in the root directory. And since my file names start with the Artist, and they play in alphabetical order, it plays 'like' albums.
And the 32 character also isn't very important. The player just truncates the name if it's too long.
#47
Well, now I'm halfway there.
I created a playlist in i tunes and copied all 80 songs to it.
I burned the MP3 disc in i tunes.
It plays all 80 songs in the car and displays the correct info for each.
The only thing screwed up now is the Track Select.
I scroll through it and select a track and a different track plays.
The track number for the track that is playing is correctly displayed, but I can't select the track I want. It just randomly picks something when I try to select a track.
Well, I guess its better than nothing.
#48
Originally Posted by gota07
I read one post that stated the variable bit rate settings can cause longer songs to stop playing before the end of the track. Anyone know for sure if this correct?
I didn't know about the 32 char limit, so I just burned a new cd of MP3's I'm going to test.
With the longer filenames it did prevent some songs from being played BTW...
#49
-DG
-DG
At the risk of sounding greedy.. ever get anywhere with this app?
#50
Originally Posted by ColdBrew
I have this happening too. They were VBR, but I haven't decided yet if that is the problem... It seems to play around 3:30 befores switching to the next song.
BTW I used Lame and Nero to create the CD.
