Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-10-2006, 10:35 AM   #1
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Default 3.5" Coax swap out in C6 Bose - Impressions
We put 3 Infinity Kappa 32.7 coaxial speakers in greenie99's new coupe yesterday, 1 each in the door trim panels and 1 in the dash. It's a very straight forward installation as once you pull the plastic trim ring off the Infinity speaker they mount directly to the stock locations. Here's a shot of removing the Bose 3.5 from the panel:
We were able to tuck the small Infinity crossovers onto the door panels using double-sided foam tape. For the dash crossover we removed the board from the plastic housing and wrapped the solder points in electrical tape. There's not a ton of space for the dash crossover without blocking the defroster vent so taking the crossover out of it's housing allowed us to bury it inboard of the speaker. This speaker just barely fits in terms of height. The phase plug of the tweet is nearly pressed against the plastic grill, but it does all fit and it all goes back together neatly.
Now for the very subjective part.....
Yes, swapping out the speakers does improve the Bose system. Absolutely improves the highs since it actually now HAS them! The sounds stage definitely improves through the midrange as well but now that the mids & highs have clarity to my ears it makes the gap down to the subs even more obvious.
Popped in a Telarc sci-fi movie soundtrack CD and that sounded very nice. Good clear strings and when the subs kick in you definitely know it. Then I put in a Patricia Barber CD. This is where the midbass gap shows. The jazz doesn't have that warm presence which is especially noticable in her vocals. We took the same CD over to my car with the Focals and you could instantly hear the difference in the midrange.
Now you absolutely BETTER be able to hear a difference between the systems or I wasted a WHOLE lot of money. But that's not really my point. What it illustrates to me is that swapping the speakers, while giving you improvement, actually makes the shortcomings of the Bose system all the more apparent.
So when you're planning out your upgrades you really have to decide what your goal is. If clarifying the soundstage and getting some true highs is enough then a swap-out of the 3.5" drivers will accomplish that. If you're looking for a true quality, complete range system though, it's time to replace all of the speakers and install a new amp.
And a gratutious beauty shot, just because a black coupe looks awesome!
TheKomoman is offline   Reply With Quote
Old 09-10-2006, 10:44 AM   #2
Steve Germany
CF Senior Member
Steve Germany's Avatar
Dan,
Nice write up! Now the fun begins... Did you disconnect the center channel yet? One of my original plans (and there were many) I thought about upgrading the center channel but quickly discounted that concept in lew of amps.
Have you done the rears yet?
Steve Germany is offline   Reply With Quote
Old 09-10-2006, 11:07 AM   #3
TheKomoman
CF Senior Member
TheKomoman's Avatar
Quote:
Originally Posted by Steve Germany
Dan,
On his setup since he was keeping the Bose amp we replaced the center with the same driver to at least maintain the same concept that Bose used. On my car the center channel is disconnected and I don't miss it a bit.
Didn't do the rears on his car. With those extremely low level, limited frequency, mono-wired wizzers back there to my mind there's no point in spending the money unless you re-wire and re-amp completely.
Old 09-10-2006, 11:27 AM   #4
Steve Germany
CF Senior Member
and to add, isolate the speakers since there is a big empty cavern behind them. I used expanding foam and built a "cabinet". Worked out nicely for my mid range bass, especially since I am running two 10in subs in the doors. It would of been cheaper to run some HQ 6in components in the doors (where was pipedreams adaptor when I was doing mine?) and it would probably been an excellent set up.
Old 09-12-2006, 02:31 AM   #5
0Audio Dave
Former Vendor
Audio Dave's Avatar
Location: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
Send a message via AIM to Audio Dave Send a message via Yahoo to Audio Dave
nice!!
Audio Dave is offline   Reply With Quote
Old 09-12-2006, 11:28 AM   #6
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
good straight forward write up
DPG is offline   Reply With Quote
Old 09-12-2006, 12:35 PM   #7
_Nomad_
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
_Nomad_'s Avatar
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
Quote:
_Nomad_ is offline   Reply With Quote
Old 09-12-2006, 02:21 PM   #8
ZBoater
CF Senior Member
ZBoater's Avatar
I did the same thing to my C6 coupe with Bose/nav and had the same impression afterwards!!
ZBoater is offline   Reply With Quote
Reload this Page 3.5" Coax swap out in C6 Bose - Impressions
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
