Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-09-2006, 05:37 AM   #1
96-speed
CF Senior Member
Send a message via AIM to 96-speed
Default JL 500/1 - Best amp for the money?
Subject says it all. I am looking to pick up the JL amp. I've looked on ebay and it seems they go for around 330 bucks (NIB). Does this sound about right?
Are there any other amps worth looking into? I like the built in EQ and remote control - those are mandatory options for me.
TIA,
Ryan
96-speed is offline   Reply With Quote
Old 09-09-2006, 11:59 AM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
I have a polk C500.1 very similar amp to the JL amp
Filter Settings
Subsonic Filter 24dB/Octave @ 15Hz
Low Pass Filter frequency 30Hz to 200Hz
Low Pass Filter slope 12 or 24dB/Octave
Also has bass boost with an adjustable frequency.
I also have the gain adjustment knob on it.
I would let it go for like 210 shipped if you are interested, was a killer amp for the few mths I used it but I needed to step up to something bigger. Let me know I can get pics and the what not.
Im sure there are also other amps out there that fit the bill for what you are looking for
http://www.polkaudio.com/caraudio/products/c500_1/
pentavolvo is offline   Reply With Quote
Old 09-10-2006, 01:32 AM   #3
adown
CF Senior Member
Look into Pioneer Premier. They have a mono and a 2 ch(bridgable) right around 600 watts at 4 ohm with the latest technology.
adown is offline   Reply With Quote
Old 09-11-2006, 03:09 PM   #4
JLTD
Junior Member
The 500/1 is very different than the other amps mentioned. Amps sold NIB on ebay will most-likely arrive DOA due to damaged cause from serial number removal. In the long run, it far cheaper to purchase the amp from the authorized retailer in your area.
JLTD is offline   Reply With Quote
Old 09-11-2006, 03:15 PM   #5
96-speed
CF Senior Member
Thanks for the info guys. I may just suck it up. I bought a RF "Punch 60" back in 1997. I blew it, and took it back to the dealer. They took it, sent it out, and I picked it up soon there after. Something to be said about brick and motor purchasing.
Thanks again.
Ryan
Old 09-11-2006, 03:32 PM   #6
pentavolvo
CF Senior Member
pentavolvo's Avatar
explain what makes the jl 500/1 so much better then the polk c500.1 ive used both
Old 09-11-2006, 06:05 PM   #7
leolufse
CF Senior Member
leolufse's Avatar
Send a message via AIM to leolufse
Quote:
The title of the original post was "best amp for the money". IMO JL doesn't belong in that category. Its a good amp, but I think its over priced. There are many amps out there that make similar power, have the same if not more options, and are far less expensive. A couple that come to mind are ppi/directed audio, phoenix gold, alpine, etc.
I have no experience with polk, so I can't comment.
leolufse is offline   Reply With Quote
Old 09-11-2006, 06:16 PM   #8
96-speed
CF Senior Member
Leo: I am open to anything right now. I couldn't find a price from a retailer online - I didn't realize JL's policy. I was thinking 400 bucks or so, but I finally found a price:
$550 seems to be the suggested retail price .
I really, really, like the "Q" feature of the crossover. Most of them have the boost, not sure if all of them have the "centering frequency," but from a theoretical stand point, that sounds exactly like what I need.
That Polk amp did not seem to offer that (from the site), and I prefer to buy new.
Can you be a little more specific about a model number that has the same (or better) EQ while performing similarly AND being cheaper? The JL may be $550, but a good separate crossover is probably 100-150 bucks. Am I way off base here? I haven't dabbled in car stereos in about 10 years.
I appreciate the feedback.
Ryan
Old 09-11-2006, 06:18 PM   #9
pentavolvo
CF Senior Member
pentavolvo's Avatar
On the polk you can select the frequency that you boost from and in all honesty you dont wanna be using bass boost to begin with it only makes it easier to send a clipped signal.
Old 09-11-2006, 06:25 PM   #10
zsr22
CF Senior Member
BCS Bet for St. Jude '09-'10-'11
zsr22's Avatar
PPI used to be good back in the day. Their Art Series amps were powerhouses. Their stuff today is alright but nowhere what it used to be. JL Audio has very good quality amps. With the patented RIPS system JL Audio uses you are able to maintain a constant 500 watts rms anywhere between 11v and 14.5v and you are able to achieve 500 watts rms anywhere between 1.5 ohm and 4 ohm, which makes JL Audio a good choice when it comes to amplifiers.
zsr22 is offline   Reply With Quote
Old 09-11-2006, 06:34 PM   #11
96-speed
CF Senior Member
Sorry, you are talking to a sound engineer idiot . Comparing this feature with the JL amp:
http://mobile.jlaudio.com/pdfs/Parametric_Equalizer.pdf
You are saying that you can lower or raise the frequency you boost from, and ofcourse the boost level, right? You can't narrow/widen the range of the frequency itself, right? This is the "Q" feature I am referring to. Let's refer this as the "width of the frequency"
I am unlike most people in that I will probably want a very narrow "width" of bass. Just enough to here the kicks and thuds of the drums, and turned up strongly. I want tight and punchy. Not all over the place. Maybe I'm thinking this feature is more magical than it really is...?
Ryan
Old 09-11-2006, 06:38 PM   #12
pentavolvo
CF Senior Member
pentavolvo's Avatar
You are correct and i read what you posted wrong you can not adjust the width on the polk. In all honesty idk why you are so concerened about the eq features id bet many of the ppl on here with nice setups dont use bassboost at all or use it to a very minimum. The jl is nice just extremely overpriced
Old 09-11-2006, 06:48 PM   #13
96-speed
CF Senior Member
It is very possible that I'm getting "suckered" by the website of JL.
The bad thing about car audio is you really don't know until its inside the car. I know I'd be happy with the JL amp. That isn't the question. The question is can I be happy with someone else that saves me 1-200 bucks...?
I might pick up an amp at BB or CC to use for a while and take advantage of the return policy. Not the most noble way to do it, but if it sounds good I'd keep it. That's the point, right? Satisfaction?
Thanks for the replies. I'll report back with results...
Ryan
Old 09-11-2006, 06:51 PM   #14
pentavolvo
CF Senior Member
pentavolvo's Avatar
Let us know how it works out, check out the kicker and mtx amps there
Old 09-11-2006, 07:16 PM   #15
leolufse
CF Senior Member
leolufse's Avatar
96, as you can see there are as many opinions about this subject as there are amps to choose from. Perhaps you can tell us more about your install and how you are planning to use the JL500/1? Since its a mono amp, I am assuming you are planning to use it to power a sub (or two). Much depends on the quality and features of your HU, the size and location of your components, the number of amps you will be running, how you will wire those amps (bridged, strapped, bi-amped) the type of enclosure you have, the music you listen to, etc.
Old 09-11-2006, 07:22 PM   #16
zsr22
CF Senior Member
zsr22's Avatar
Ryan
Best Buy and Circuit City are two stores that I do not buy car audio equipment from. I guess its something about buying an amplifier from a store that also sells refrigerators that makes me feel funny.
Old 09-12-2006, 12:27 AM   #17
96-speed
CF Senior Member
Sorry, any part might be great in an ideal situation, but without knowing what my intention/expectations are, you guys can't help.
2001 C5
Stock Head unit
PAC Converter
Stock speakers 10w3 D4 (running 2ohm)
Probox
Update: I went to Circuit City tonight and looked around for a bit. They had a Kicker amp that seemed similar in power to the JL, but it was ~$475 - not much difference in that or the JL.
I ended up picking up this amp:
Eclipse XA1000. Rated at 480watts rms @ 2ohm
Link:
http://www.eclipse-web.com/amp/xa1000.html
I bought it for ~$285 and paid $40 for a 2year warranty. I got it all hooked up tonight and it provides more boom than I need. With this in mind, I haven't had much time to tune it. Quite frankly, I'm not sure where to start. Initial opinion is that the box and speaker sound very tiht and punchy - not loud and sloppy .
Anyone want to tell me where to start the input and boost settings on the amp? Right now the amp is set to around 3db boost and the input is around 2/3 on the dial. My PAC converter is set around 3/4 (as it came from PAC). Does that make sense?
I have thirty days to listen to it and take it back if I want. That is the reason I bought it from CC. If they offered no guarantee, I'd go to a local stereo shop.
I'll report back with a better opinion in a couple days.
Ryan
Old 09-12-2006, 01:08 AM   #18
pentavolvo
CF Senior Member
pentavolvo's Avatar
The higher the bass boost the more boom you will feel on the low end. Set the gain so that with your volume blasted on the radio the sub isnt distorted, or if thats too much turn it down a bit more. Leave the gain on the PAC adapter unless you are maxing or bottoming out the gain knob on the eclipse. Its a very nice amp
Old 09-12-2006, 01:15 AM   #19
96-speed
CF Senior Member
Pentavolvo: You've been a big help. Thanks .
FWIW, I turned the Lowpass all the way down, and it sounded/felt pretty good to me. I think I was a marketing victim by JL. I'll go out tomorrow morning and set the gain, and finally tinker with the boost while I'm driving. I mounted the amp behind the passenger seat, so it is very easy to get to. I am also happy that it is very small.
Ryan
Old 09-12-2006, 01:38 AM   #20
pentavolvo
CF Senior Member
pentavolvo's Avatar
set the lowpass at roughly 80hz. I apologize if it seemed liek i was bashing your decision on JL i was just tryin to say there is other great stuff out there for less money.
Reload this Page JL 500/1 - Best amp for the money?
Tags
amp, jl, money
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Steal this 99 6spd vert...with Supercharger TANGLVR C5 Corvettes for Sale 34 07-23-2005 09:21 AM
Need advice/clarification on component speakers for a C5 sjn25600 Audio/Electronics 20 06-15-2005 01:57 PM
(CA) 1993 Auto Green Coupe $10,500 with many extras. Goody C4s for Sale/Wanted 11 02-17-2004 01:36 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
