Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-08-2006, 05:06 PM   #1
_Nomad_
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
_Nomad_'s Avatar
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
Default ~*Putting AVIC D2 in C6, What all will I need???*~
I'm putting a Pioneer AVIC D2 in my C6….anyone done this yet?
Does the D2 require I find the VSS (Vehicle Speed Sensor) wire to connect to? Some Double Din systems do, some don't. If so, where is the VSS wire in the C6?
Does the AVIC D2 require reverse signal wire hookup too?
I know that I will need THIS mounting kit.
I know that I will need THIS to have XM.
I was told that I could use my stock XM antenna for the aftermarket XM receiver. I imagine I would have to cut the stock harness though. Does anyone know?
I believe I will need THIS to retain the chimes and OnStar, but I'm not sure yet.
Will I need any other wiring harnesses? Am I leaving anything out?
_Nomad_ is offline   Reply With Quote
Old 09-08-2006, 05:19 PM   #2
_Nomad_
CF Senior Member
_Nomad_'s Avatar
I think I am forgetting an antenna adapter.......
Old 09-08-2006, 08:02 PM   #3
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Yep, you'll need all of that above, including the chimes and antenna adaptors.
The XM antenna itself could certainly be used but I have read that if you don't have XM in your car to begin with the wiring harness isn't present for it.
Have you checked out www.avic411.com ?
TheKomoman is offline   Reply With Quote
Old 09-08-2006, 09:13 PM   #4
_Nomad_
CF Senior Member
_Nomad_'s Avatar
I have the Blose 7 speaker, 6 disk in-dash changer with XM and OnStar stock. I even have that attractive "beauty mark" on the roof bow.
I'll give that website a look, thanks. It would be nice if a C6 owner would have gone this rout for vehicle specific info...ya know?
Old 09-08-2006, 10:11 PM   #5
TheKomoman
CF Senior Member
TheKomoman's Avatar
Almost has to be somebody out there that went that route, but went that route self-installed.....
If you have a coupe the XM module is mounted over the left rear wheel. Where the antenna leads go from there I don't know(my C6 is a vert and it's mounted in the waterfall). If you mount the Pioneer unit there you may be able to tap power and the antenna, then just run the signal cables up to the head.
Reload this Page ~*Putting AVIC D2 in C6, What all will I need???*~
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
