Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-08-2006, 12:19 PM   #1
Mr. Blue
CF Senior Member
Mr. Blue's Avatar
Default LED question
I know that it's not audio, but IT IS electronics.
I installed a set of the halo LED tail lights, and I have a sequencer installed also. I have the "fast blink" syndrome. Is there a fix for this that will let me keep the sequencer in the circuit?
Mr. Blue is offline   Reply With Quote
Old 09-08-2006, 01:46 PM   #2
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
i believe it's done with a resistor. it's a common problem with bikes when we change out our turn signals. Sorry i'm not much help but maybe that will get you pointed in the right direction
scott_fx is offline   Reply With Quote
Old 09-08-2006, 04:34 PM   #3
MAGRED2001VETTE
CF Senior Member
The blinker relay and flash rate works off of the load (resistence) in the tail lamp.
Scroll down in this link, you will need one for each tail light...
http://www.superbrightleds.com/cgi-b...2.1140&next=50
MAGRED2001VETTE is offline   Reply With Quote
Old 09-08-2006, 07:37 PM   #4
Fasthotrod
CF Senior Member
Fasthotrod's Avatar
UnderRADAR
Send a message via AIM to Fasthotrod
You guys are right on the money!
The flasher works by (and is dependent on) the amount of current flow in the flasher circuit. The flasher uses a bi-metal tab that works like a relay contact. As the current flows though the bulbs, heat is generated in the metal tab, causing it to bend and opening the circuit. The metal tab cools and the circuit is re-enabled. Blink-blink-blink.
LED's are much, much more efficient at producing light, therefore are low current devices. They just don't pull the current required to heat up that element properly.
Using a resistor for each taillight blinker should cure your 'quicky-blinky' problems. Just place it in parallel with the LED terminals.
Hope this helps.
Mark
Fasthotrod is offline   Reply With Quote
Old 09-09-2006, 08:30 AM   #5
2k2C5
CF Senior Member
Support Corvetteforum!
2k2C5's Avatar
Since the Halo LED lights already have a resistor circuit built into each light the problem is with the taillight sequencer. From what I have gathered from others that have tried this is the LED's and sequencer are not compatible.
2k2C5 is offline   Reply With Quote
Reload this Page LED question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Finally! Tech Tips on how to change your DIC, Mirror, and HVAC Lights to LEDs! + Pics SpdKilz C5 General 75 03-24-2005 03:06 PM
Stylin Concepts LED '1157' Replacements vs. Flasher pws69 C3 Tech/Performance 26 09-28-2002 10:54 AM
I picked up a nail last night which led to this question.. rosecustom C5 Tech 11 09-12-2002 05:34 PM
Competition Mode Question johnma C5 Tech 18 04-09-2002 11:51 PM
Led Taillight Conversion Kit ACCURATE C5 Tech 11 01-30-2002 06:47 PM
Would you be interested in this new lighting safety product for your C5's LED Third Brake Light? L.A.P.D. C5 Tech 119 01-13-2002 10:40 PM
You're going to hate me for this question. Mark C ZX9 C5 Tech 16 12-07-2001 07:07 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
