Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-10-2006, 06:28 PM   #1
alyle5864
CF Senior Member
alyle5864's Avatar
Default Audio problems
Well I recieved a replacement head unit for my 1986 Delco/Bose. Installed it and I've got no sound. The original did not work at all. This one appeares to be working as I can tune different stations and I see the stereo light coming on. It switches to AM and FM okay.
Can all four amps in the speakers be bad? Is there any way to test these? I know they can be rebuilt at about $75 each but with that cost I might as well replace the whole system. Not even static coming from them. Is there a fuse somewhere for the power to the amps?
Those that have replaced the system, did you use existing wireing or did you rewire the car?
alyle5864 is offline   Reply With Quote
Old 08-10-2006, 06:49 PM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
the relay is fried... I just don't remember where it is on an 86...
bogus is offline   Reply With Quote
Old 08-10-2006, 07:51 PM   #3
alyle5864
CF Senior Member
alyle5864's Avatar
Well I did some troubleshooting. Pulled one of the rear speakers and tested it and it works fine. Used my voltmeter and checked the voltage coming to the amp, 3 volts. Is this supposed to be 12v?? Haven't a clue where the relay is either.
Old 08-11-2006, 12:33 AM   #4
Dads90
CF Senior Member
Dads90's Avatar
Send a message via AIM to Dads90
My 90 had a am/fm tuner modulator mounted behind the glove box. My radio would make wierd sounds and I thought it was my speakers, but after testing them they were ok. Sometimes it would buzz pop or make no sound. I have a local vette part sell me that used tuner box for about 75 bucks. Replaced it and it solved the problem, might think about that!
Dads90 is offline   Reply With Quote
Old 08-11-2006, 02:48 AM   #5
Steel Breeze
CF Senior Member
Steel Breeze's Avatar
Send a message via MSN to Steel Breeze
Quote:
Should be 12V. The relay in my 88 is up under the passenger side access panel. It is a #itch to reach. You are almost standing on your head. Some folks recommend pulling the wiring socket off the bottom of the relay, then installing a new relay, then taping it to a wiring harness in the vicinity, so as not to rattle around. I'm strange however, I like to put things where they are supposed to be, but thats just me. The other will work fine. Good Luck...
Steel Breeze is offline   Reply With Quote
Old 08-11-2006, 12:02 PM   #6
bogus
CF Senior Member
that damned relay moved around... on the 90-96s, it's near the steering column...
I think in some vintages, it's behind the DIC, but I am not 100% sure.
Start with the suggestion from steel breeze.
Old 08-14-2006, 02:38 AM   #7
Steel Breeze
CF Senior Member
I believe GM purposely tries to fluster us. Then have a good laugh when we can fine a relay, or a gas pedal, or something...
Reload this Page Audio problems
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Audio FAQ bogus Audio/Electronics 49 01-31-2012 04:41 PM
C6 FAQ audio - look here first! Steve Germany Audio/Electronics 24 09-04-2008 11:05 AM
This could be a solution for our C6 poor audio CROWVETTE C6 Corvette General Discussion 17 08-26-2005 06:22 PM
New Sound System Packages at Complete Dreams accidentprone C6 Corvette General Discussion 36 06-10-2005 12:55 PM
Automatic Volume Control Question dave7933 C6 Corvette General Discussion 15 02-03-2005 01:19 PM
Lots of C5 Parts + Audio Equipment FOR SALE C5-VERT C5 Parts for Sale/Wanted 15 07-09-2002 05:16 PM
help my 84 before i run it off a bridge (audio problems) MattS4313 C4 Tech/Performance 9 01-02-2002 05:30 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
