Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-10-2006, 02:50 PM   #1
miguel94
CF Member
miguel94's Avatar
Default boston Acoustics Pro 6.5" for C6Z doors?
Just wondering what everyone's opinion is on using this setup in the doors?
This is currently being installed in my 07Z and just wanted to get some feedback on pros / cons. Install also includes the following:
JL Stealthbox
JL 250/1 amp (for stealth box)
JL 300/4 amp (2 BA Pro 6.5" in front, Stock Rears only for fill. Or maybe remove the rears and send 150 to each BA Pro /shrug)
JL Cleansweep
Thanks in advance,
M
miguel94 is offline   Reply With Quote
Old 08-10-2006, 05:29 PM   #2
MAGRED2001VETTE
CF Senior Member
VERY high end components for a very expensive car to short yourself on a simple aftermarket (Alpine/Eclipse) headunit that would complete the install....your stereo is only as good as its weakest link . Also up grade the rears while you're at it. Afterall we are only talking about a few hundred more dollars to do it right on an $80,000+ total expense!
The "JL Cleansweep" adaptor is only a rigged way of making a cheap HU have RCA outs. Any REAL high quality HU will already have these and your factory rears are most likely not 4 ohms either.
If we were teenagers on a limited budget for a used car in high-school I'd be more open minded to people cutting corners, but anybody that buys a new vette and ZO7 for that matter better not use "money" as a reason. You will be SOOOO much happier if its done right the first time.
MAGRED2001VETTE is offline   Reply With Quote
Old 08-10-2006, 06:42 PM   #3
Smooth72
CF Senior Member
Smooth72's Avatar
Kevin Lowe
I called JL audio and they said on the Bose C6 unit you did not need the the clean sweep especial if you are using the slash amps. Just tap in the Bose sytem before it goes to the Bose amp. You could take that money and apply it to speakers. Jl has a great Tec service department, I got it off of thier web site.
Smooth72 is online now   Reply With Quote
Old 08-10-2006, 08:10 PM   #4
Moto
CF Senior Member
Nice set of stuff you have that. Like Cmooth72 said, a Clean sweep is not needed for a the Bose C6.
As for changing out the Bose headunit, I wouldn't do that. You'll ruin the factory look and invite people to break into your car. Beside, the headunit is not the weak link in the Bose system.
Moto is offline   Reply With Quote
Old 08-10-2006, 09:56 PM   #5
miguel94
CF Member
miguel94's Avatar
about the headunit. I decided not to change it because I couldn't find one that could adapt to the HUD on the C6 (you get radio/XM/NAV information in the HUD). To my knowledge there is no aftermarket adapter to replicate this function. So for the time being, stock HU stays in.
My installer is actually having a problem with using the cleansweep, maybe some of the pros or someone with experience configuring it can chime in ... basically he says there are 2 wires (signals) coming from the HU/factory amp to the doors. One provides the highs for the tweeter. The other is providing lows for the woofer (Door speaker looks like a 10" woofer/tweeter combo crap)... anyways, seems like if he uses either speaker to feed the cleansweep, it sounds like crap (speaker 1 give all crisp highs, no mids, speaker 2 gives only lows).
Also tried getting the signal before the factory amp, but said it didn't give him anything. I don't know how you are supposed to get the signal before for the factory amp, and not use the cleansweep at all. Maybe someone who went this route can chime in here...
Calling JL Tech support tomorrow morning to see what the recommended path is on this particular setup.
BTW I am using the cleansweep for the amps and the aux input for my ipod, since Nuecleus 2Xi isn't working perfectly yet. Setup sounds great through the Ipod --> cleansweep --> amps --> speakers.... but when I switch over to the HU it is plain crap.
THanks for any advice that you can provide.
M
Old 08-10-2006, 10:01 PM   #6
miguel94
CF Member
miguel94's Avatar
Quote:
"Money" is not the issue... just can't find a HU that can reproduce all the factory HU's bells and whistles. (i.e. output to the HUD). I do love the idea of an alphine W200 or similar, or even pioneer Z1 (I had a similar unit in my C5 corvette, and I miss the DVD playback and TV)... but I am waiting for a fully integrated solution.
M
Old 08-10-2006, 10:04 PM   #7
miguel94
CF Member
miguel94's Avatar
Quote:
What do you mean by "Slash amps" ... can you reference where you found any information on using the JL amps direct from the factory HU without the cleansweep or similar unit?
Thanks in advance,
M
Old 08-10-2006, 10:31 PM   #8
miguel94
CF Member
miguel94's Avatar
Quote:
Thanks in advance,
M
Nevermind... I did some research and found the solution myself. ECS cables direct from the HU (before the Factory amp) to the JL Slash series amps. Gonna give this a try tomorrow and hope for the best. Shouldn't need the cleansweep after this.
But going to need an alternative to connect my Ipod.
M
Old 08-11-2006, 02:09 PM   #9
Smooth72
CF Senior Member
Smooth72's Avatar
Kevin Lowe
I am Glad that this Oklahoma Sooner was able to help a Miami Fan.
Old 08-11-2006, 11:33 PM   #10
miguel94
CF Member
miguel94's Avatar
UM doesn't play OU this year, so we can be friends.
Thanks for the help. BTW: final config turned out to be:
BA Pro 65 (front doors)
BA SL 65 (rear panels)
JL 300/4 amp
JL 250/1 amp
JL C6 Stealthbox (arrives tuesday, problem with shipping )
Valentine 1 Radar detector
Blinder M-20 Laser jammer
Will have pics tomorrow after the car is clean, and have sunlight for the pictures.
Only one more problem to iron out. Picking up some engine noise in the speakers. My installer believes that the factory HU voltage output is too weak and needs a line driver. We will be working on this problem over the weekend. Anyone have any experience with this problem?
Thanks in advance,
M
Old 08-12-2006, 01:21 AM   #11
_Nomad_
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
_Nomad_'s Avatar
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
Thanks in advance,
M
You said you were running a Cleansweep. The Cleensweep already acts as a line driver by boosting the output voltage from the stock HU, which if I remember correctly puts out 2v? So if you are experiencing engine noise with the Cleensweep hooked up then it is not a voltage output problem.
Did the installer ground the aftermarket amps and all of the other components to one point at the battery? If not, that could be your problem. Professional installers sometimes have a bad habit of grounding to the seat bolt. Also make sure he didn't run the power wire near any speaker or RCA wires.
_Nomad_ is offline   Reply With Quote
Old 08-12-2006, 01:23 AM   #12
_Nomad_
CF Senior Member
_Nomad_'s Avatar
Thanks in advance,
M
CLICK HERE
Old 08-12-2006, 01:31 AM   #13
miguel94
CF Member
miguel94's Avatar
Quote:
We pulled the cleansweep out. thanks to the recommendation of other forum members . (the cleansweep is not needed on the factory HU).
look at the end of my post, it details all the components in the final setup. But your info does point me in the same direction (2v off the factory HU is probably not enough, and most likely the source of the engine noise). Maybe my installer is on the right track. We'll see soon.
M
Old 08-12-2006, 01:38 AM   #14
miguel94
CF Member
miguel94's Avatar
Thanks in advance,
M
Turns out you can use JL Audio ECS cables to connect straight from the factory HU to the JL Amps (they have a Differential-Balanced input).
M
Old 08-12-2006, 04:27 PM   #15
miguel94
CF Member
miguel94's Avatar
Default Installed [PICS]
Here are the install PICs:
Door Speakers (BA Pro 65):
Rear Speakers (BA SL 65):
JL 250/1 amp:
JL 300/4 amp:
BA Sub (temporary till stealthbox arrives Tuesday):
Blinder M20 Switch:
Blinder Transmitter: (Picture brightness increased so you can see them behind the front grill)
Valentine 1: (Mounted on Glass)
Reload this Page boston Acoustics Pro 6.5" for C6Z doors?
Tags
65, acoustics, boston, miguel94, pro
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
