Quote:
Originally Posted by bangand0lufsen
Does anyone know how to take the front bose speakers out. Its a 93 40th with bose gold series.. I took out the 2 screw on the outside after you open the door but its still very stuck any ideas or help would be great thanks.
There should be more than two screws-look along the outside of the sill cover, and you may want to remove the piece that covers the inside edge were the rug meets the door sill. the speaker cover is attached by velcro to the speaker enclosure, and is very hard to remove; make sure the sill cover is loose before trying to remove the speaker cover.
Hope this helps. If you are going to work on your car, you should get a helms manual; they are worth there weight in gold.
Randy
