Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-07-2006, 09:04 PM   #1
LS WON
CF Senior Member
LS WON's Avatar
Default Stereo reception terrible on Factory unit
On FM I get static that is in the signal on all stations even if the station is powerful and also the reception is not good as the signal fades out. Is there some type of reprogram or upgrade a dealership can do to make this factory radio better? it is the factory system but doesn't have the word BOSE on the speakers so I'm not sure if it is made by BOSE .
LS WON is offline   Reply With Quote
Old 08-07-2006, 09:29 PM   #2
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
what year is your car?
DPG is offline   Reply With Quote
Old 08-07-2006, 10:13 PM   #3
LS WON
CF Senior Member
LS WON's Avatar
Quote:
2005 stereo that came in 1SA package.
Old 08-07-2006, 10:38 PM   #4
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Quote:
This is NOT normal, and no, your system isn't Bose - and even if it were it's only the amp & speakers that are Bose, not the head. Assuming you're not over the mileage the '05 is still under warranty. I would call the dealer and bitch & moan, especially if it is a constant thing. There is either a software fix, a head replacement or there could be a ground issue going on in that car - regardless, it's under warranty.
TheKomoman is offline   Reply With Quote
Old 08-07-2006, 11:46 PM   #5
LS WON
CF Senior Member
LS WON's Avatar
Quote:
Any idea on who makes the head unit?
I did contact the dealer and they told me there is no recall/TSB or anything about stereo reception of radio stations.
They didn't even know what I was talking about regarding a software fix.
Old 08-08-2006, 08:25 AM   #6
TheKomoman
CF Senior Member
TheKomoman's Avatar
I think you need to take a different tack with them - instead of asking if there's a TSB tell them the unit is defective. If that dealer doesn't help then call another or contact Chevrolet customer service - there is a problem with your radio reception and it is a warranty issue and they should repair or replace it.
I know that the NAV unit is made by Denso but I don't know who makes the non-NAV head, sorry.
Old 08-08-2006, 10:27 AM   #7
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
take it in and just say that the radio isnt working. this is what warranties are for and if it is a bad ground, i would want that fixed right away. dont want any kind of drain on the battery.
Old 08-08-2006, 04:38 PM   #8
LS WON
CF Senior Member
LS WON's Avatar
I think all of the above is true and you guys are correct. I just couldn't imagine a stereo system being this bad even if it is factory. This is in regards to FM reception with a strong signal there is hissing in it (static) no clear signals I thought it could be the antenna system. It certainly isn't the terrain because it happens everywhere all the time. So off it goes perhaps they might put in a new head unit by BOSE instead of this Pioneer head unit that comes with the 1SA unit.
Old 08-08-2006, 04:41 PM   #9
LS WON
CF Senior Member
LS WON's Avatar
I believe the head unit on the 1SA package is Pioneer No Navigation unit and the P/N relating to firmware disk upgrade is 15853651
Found this in the General C-6 Discussion under C-6 FAQ Pg. 1.
Old 08-08-2006, 09:37 PM   #10
LS WON
CF Senior Member
LS WON's Avatar
I wish I knew who made the head unit for the 1SA and 1SB packages? I heard it was Pioneer. No one seems to know.
Old 08-09-2006, 09:48 AM   #11
TheKomoman
CF Senior Member
TheKomoman's Avatar
While I can undestand the curiosity, I'm not entirely certain why it matters with regards to replacing or getting it fixed.
Old 08-09-2006, 10:02 AM   #12
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
i think the easiest way would be to pull the center consol and just get to the headunit. it should have manufacturer labels behind it. But im not sure if its worth it at this time to go back there just to see the brand, but then again, it just might be
Old 08-09-2006, 04:58 PM   #13
LS WON
CF Senior Member
LS WON's Avatar
No I'm not really interested in finding out what brand it is I just want to get rid of the static I pick up on strong signals actually all signals then the signal will fade out. I checked the C-6 FAQ under Radio problems but most of thoses fixes are for stereos with navigation units and Mine doesn't have a navigation unit. It is the 1SA package stereo. I just want to find out the disc upgrade P/N number to fix this thing.
Old 08-09-2006, 05:16 PM   #14
TheKomoman
CF Senior Member
TheKomoman's Avatar
From all the digging you've done, it seems like there IS NOT a disc upgrade for your radio. You have something wrong in the car. Whether it's the radio itself, antenna module(there is a separate powered FM antenna module), a grounding issue, etc is for the dealer to figure out, unfortunately. You will likely have to ride them on it as this screams like something the dealer will throw their hands up over and say "we can't find anything wrong." I'd make an appointment where you can take the service manager out to the car and demonstrate the problem, even if that involves taking a ride to prove it's not location based.
Old 08-09-2006, 05:42 PM   #15
Zuntov
CF Senior Member
Zuntov's Avatar
I checked the serial tag of my original Base US8 radio/cd player. The only recognozable name on the tag is a GM logo and Siemens VDO after it.
Zuntov is offline   Reply With Quote
Old 08-09-2006, 06:02 PM   #16
LS WON
CF Senior Member
LS WON's Avatar
At this point I concur with you 100% as this is what it logically leads me to believe of what possible problems are left.
Maybe I will also have them do that thing with the air conditioner too where you get that musty smell I believe they spray something like lysol into the vents or do something to kill that fungi in system. If I send it in might as well send it in for anything else that is bothersome or annoying and just not right.
Old 08-09-2006, 06:10 PM   #17
LS WON
CF Senior Member
LS WON's Avatar
Quote:
But you have navigation right? I never heard of Siemen's brand and what's a VDO? doesn't Siemen's make cellphones?
Old 08-09-2006, 07:25 PM   #18
Zuntov
CF Senior Member
Zuntov's Avatar
Nope, I had the base US8 stereo with the U66 speakers.
Siemens is huge. They manufacturer a wide variety of electronic hardware.
I went to their website and checked on their mutimedia products. Guess what, the Seimens line of car audio head units is called VDO. So, I would conclude that Siemens is the OEM for our base radios anyway.
http://www.vdodayton.com/default2_an...u=devices.aspx
Old 08-10-2006, 04:41 PM   #19
LS WON
CF Senior Member
LS WON's Avatar
So Seimens is the head unit for the 1SA stereo and the 1SB stereo on our Corvettes? The 1SB has "BOSE" written across the speakers?
How does Seimens compare to sony, Pioneer, Alpine, Delco?
Old 08-10-2006, 06:58 PM   #20
Zuntov
CF Senior Member
Zuntov's Avatar
By looking at the Siemens VDO website, I would say they make some decent aftermarket heads. I doubt that GM would have the vette's base stereo performance specs. would be anywhere near that of any decent aftermarket unit.
I know the Alpine unit I installed made a big difference in sound and clarity using the base amp and speakers.
Reload this Page Stereo reception terrible on Factory unit
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
