Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-06-2006, 08:26 PM   #1
JCAIRE2
CF Senior Member
JCAIRE2's Avatar
Default Recommend some 3-way components
Need to upgrade the system in my other car. It has 3-way speakers in front and I'm having a hard time finding decent 3-way components to browse. Any recommendations. I need a 5 1/4" set. I'm on a budget as well.
JCAIRE2 is offline   Reply With Quote
Old 07-06-2006, 08:34 PM   #2
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
i'm not sure if 5.25" 3 way components exist....are you sure you're not talking about 5.25 3way coaxials?
scott_fx is offline   Reply With Quote
Old 07-06-2006, 08:52 PM   #3
fej
CF Senior Member
fej's Avatar
Yep what Scott said. I think the smallest 3 way set I have seen is a 6" 3 way ... many people make 6.5"/3-4"/tweet sets. A friend of mine I just helped out with an install in his M3 got a set of 5.25"/3"/tweet from Rainbow (very solid upper end brand) + a 4"/tweet component set for the rear for like $600. I thought that it was a great deal for the quality of the component. Obviously it would not be a plug and play deal for our cars but easily adaptable.
Could also just piece together the size set that you want from home drivers and have a crossover built to spec.
Fej
fej is offline   Reply With Quote
Old 07-06-2006, 09:57 PM   #4
Xtreme5053
CF Senior Member
Send a message via AIM to Xtreme5053
Dude...don't put some 5.25s....put some 15"s dawg! Big bump in the door trunk man!! Fo' sho'.....
Xtreme5053 is offline   Reply With Quote
Old 07-06-2006, 10:28 PM   #5
scott_fx
CF Senior Member
scott_fx's Avatar
Quote:
wow...somebody has gotten a jump start on a bottle of JD
Old 07-06-2006, 10:29 PM   #6
Duramax Dave
CF Senior Member
I'll second that motion...
Duramax Dave is offline   Reply With Quote
Old 07-07-2006, 01:52 AM   #7
JCAIRE2
CF Senior Member
JCAIRE2's Avatar
Fej
That's good to know about the rainbow drivers. This is actually for my BMW, lol so that's right on topic. I'm not sure if I can fit 6 1/2" drivers in the kick-panels, but will find out as that would make my life easier. I have not run across any 5 1/4" 3-ways yet, but will look at the rainbows, though they are a little more than I was looking to spend.
I plan on having a 3-way component set up front, a nice 4" replacement for the rear location and 2 12's in the trunk.
THanks
Old 07-07-2006, 02:15 AM   #8
stinky
CF Senior Member
stinky's Avatar
Quote:
I don't know if "budget" will qualify any of these but they are 5 or 5.25 3-way: morel has a 5" Elate 5, Digital Designs (ddaudio.com) ddmb5.2, and DLS (dls.se) UP35.
stinky is offline   Reply With Quote
Old 07-07-2006, 11:20 AM   #9
fej
CF Senior Member
fej's Avatar
Do a google search for X year BMW replacement speakers ... found a shop that way that sells kits that include the tools to pull the panels off + speakers and all hardware. They sound pretty damn good in my buddies M3 (2001 I think) I think the rainbow package was a $100 upgrade over the stock replacement package .. can't remember for sure
G'luck
Fej
Old 07-07-2006, 03:40 PM   #10
bogus
CF Senior Member
Send a message via Yahoo to bogus
The thing with 3-ways is the bigger bass driver helps bring the bass forward.
Mine are Canton Pullman RS3s. 6"/4"/1".
Check CDT, they make a nice 3-way set.
If you are putting these into a C5 door, (or C6 for that matter), I would consider an 8" midbass... with the 4" and 1", it should sound SWEET.
This is where bigger IS better.
Another thought is to build a 3-way set from components, and have someone wire you up a passive crossover, or, get an active crossover.
bogus is offline   Reply With Quote
Old 07-15-2006, 12:47 PM   #11
71'AirStrike
CF Senior Member
71'AirStrike's Avatar
Can an 8" fit in the door while still looking stock? Im looking at a 3 way system for sheer volume. I have a vert and I want to listen to music with the top down at 120mph.
With 8"s in the door I could ememinate the 10" sub in the back...hmmmm
71'AirStrike is offline   Reply With Quote
Old 07-16-2006, 01:33 AM   #12
mathia
CF Senior Member
mathia's Avatar
You can fit a 3 way with an 8" mid bass in C5 and still have it look stock. I think. I'm in the process of doing it now, just not sure exactly where I'm going to put the tweeter behind the door panel so it's not blocked and well aimed.
Here's a thread of someone who put a 4" mid and 8" mid bass behind the stock door panel. I think they mounted the tweeter in a non stock looking location. Hard to tell as most of the image links are no longer good.
http://forums.corvetteforum.com/show....php?t=1189073
My install uses a much simpler mount, just a single 3/4" piece of MDF, but it took several rounds of fit and trim and there is barely enough room for everything. I've been taking pics and will post a write up once I actually get some sound out of it. I'm using Kicker SSMB8 mid basses and CDT CL-41 components which have a 4" mid and a 1" dome tweeter.
mathia is online now   Reply With Quote
Old 07-16-2006, 12:22 PM   #13
scott_fx
CF Senior Member
scott_fx's Avatar
8" in the door will produce some nice bass but will never beat out a 10" in the back with a correctly built box.
Old 07-16-2006, 12:43 PM   #14
fej
CF Senior Member
fej's Avatar
I have a 7" midbass and a 3" dome midrange in my car atm (almost a 4" cutout) and the space in the factory hole is pretty stuffed. I had to build a small MDF trim ring to space the midrange (effectively sits on top of the frame of the 7") and even doing that I still have about 30-35% of the midrange dome blocked behind the factory door panel (the area where the controls for the door sit above the factory grill). I think this winter when I have more time I am going to play some more with speaker locations to try and get them better aimed but I know for sure that an 8" midbass and a 4" midrange will certainly be blocked some and will probably be stuffed into the factory holes (unless they are both pretty small magnet structures)
G'luck
Fej
Reload this Page Recommend some 3-way components
Tags
525, components
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Audio FAQ bogus Audio/Electronics 49 01-31-2012 04:41 PM
need help on upgrading my sound system.... 1990dtgL98 Audio/Electronics 14 12-25-2003 09:26 PM
Recommedations for a new C5 stereo...? aurik Audio/Electronics 19 11-21-2002 01:36 AM
Have to release clutch pedal almost all the way before engagement? n1kki6 C4 Tech/Performance 17 05-16-2002 05:14 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
