Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2006, 11:46 AM   #1
debmwb
CF Senior Member
debmwb's Avatar
Default 2004 C5 Battery Power
Those of you with 2004 C5's that have the different battery cables...How did you attach your power wiring for your amps (pics please)?
debmwb is offline   Reply With Quote
Old 07-04-2006, 06:24 PM   #2
Xtreme5053
CF Senior Member
Send a message via AIM to Xtreme5053
Just different battery terminals....I have a different battery as well though...
http://kinetikaudio.com/hc1800.asp
__________________
2004 LeMans Blue Z06
Focal/Audison Show Car
USACi - http://www.soundoff.org/usaci.htm
Look for me at Texas Heatwave!
Xtreme5053 is offline   Reply With Quote
Old 07-04-2006, 07:46 PM   #3
fej
CF Senior Member
fej's Avatar
I have a red top Optima with dual posts and I have my positive cable on the top post for my stereo gear (with new terminal from Knuconceptz). I have not had time for my big 3 upgrade but will be adding my other terminal and using the top negative post for the ground improvements. Normal car connections are via factory terminals at the side post location.
Fej
fej is offline   Reply With Quote
Old 07-06-2006, 12:39 AM   #4
0Audio Dave
Former Vendor
Audio Dave's Avatar
Location: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
Send a message via AIM to Audio Dave Send a message via Yahoo to Audio Dave
If you are keeping the stock battery, but hooking up an amp to it, you can use a part by Stinger of AAMP of America called a SGMBatt. It is a battery post adapter that allows you to hook up your amp power cable to it. Is this what you are needing? It will work with any sidemount post battery as well...
Audio Dave is offline   Reply With Quote
Old 07-06-2006, 10:27 AM   #5
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
knewblewkorvette's Avatar
Here's mine.
knewblewkorvette is offline   Reply With Quote
Old 07-08-2006, 12:36 AM   #6
debmwb
CF Senior Member
debmwb's Avatar
So did you just cut off the original terminals?
Old 07-08-2006, 12:43 AM   #7
Xtreme5053
CF Senior Member
Quote:
The battery I have in there has two top posts. The wire connectors you see there just clamp onto them. Looks like the same thing with the Optima in the post above yours.
__________________
Old 07-08-2006, 12:45 PM   #8
debmwb
CF Senior Member
debmwb's Avatar
Okay, so you did not modify the original pos and neg terminals for the car? The one's on top of your battery are just for the audio?
Old 07-08-2006, 10:14 PM   #9
knewblewkorvette
CF Senior Member
My top terminals are just for the stereo (0-guage wire) and the side terminals are used for the factory wiring.
Old 07-10-2006, 01:11 AM   #10
debmwb
CF Senior Member
debmwb's Avatar
That is a difference with the '04 C5, they changed the battery cables. This is why I'm asking the question. My '04 has battery cables that attach to the top posts. I'm trying to figure out how to connect the audio cables without changing my battery. If my battery was going south, I'd replace it with an optima and put the cables on the top posts and the audio on the side terminals.
Old 07-10-2006, 01:49 AM   #11
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
Sorry I dont remeber what the battery looks like on an 04, can you post a pic and I can help you out
pentavolvo is offline   Reply With Quote
Old 07-10-2006, 01:49 AM   #12
pentavolvo
CF Senior Member
pentavolvo's Avatar
Old 07-11-2006, 09:53 PM   #13
debmwb
CF Senior Member
debmwb's Avatar
Quote:
I will post a pic this weekend after I get back from travel.
Old 07-16-2006, 05:48 PM   #14
debmwb
CF Senior Member
debmwb's Avatar
okay...here are some pictures of the connections to my '04 Coupe.
and a close-up of the terminal...
See...this is my dilemma. They are not regular terminals by any stretch of the imagination! Obviously if I replace the battery for say an Optima with both top and side terminals I have it made. I don't know how to fix what I have without cutting the ends off and changing the terminals.
Old 07-16-2006, 07:39 PM   #15
wiz1500
CF Senior Member
wiz1500's Avatar
Send a message via AIM to wiz1500
If you take the end of the terminal where the wire comes in and straighten it out you should be good to go......I had to cute mying off.
Two things please don't make fun of the dust and I no the screw on the + side is not stainless. (yet)
wiz1500 is offline   Reply With Quote
Old 07-17-2006, 09:18 PM   #16
knewblewkorvette
CF Senior Member
Hey wiz,
You need to dust off that battery. While your at it, you should replace that bolt with a SS one
Old 07-18-2006, 12:17 AM   #17
wiz1500
CF Senior Member
wiz1500's Avatar
Quote:
Originally Posted by knewblewkorvette
Hey wiz,
There's a SMART ONE in every croud...... (usually it's me)
Thanks for the advise......
Old 07-18-2006, 02:09 AM   #18
Chief777
CF Senior Member
Chief777's Avatar
Here's mine.
Probably a noob question, but what's the small red and black lines for? Also, what the advantage of running the ground back to the battery?
Chief777 is offline   Reply With Quote
Old 07-18-2006, 12:05 PM   #19
wiz1500
CF Senior Member
wiz1500's Avatar
Quote:
Let me be the first to take a guss...........I say there for a trickle charger.... .....
Old 07-18-2006, 01:33 PM   #20
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
Quote:
yup thats what my little black and red wires are for. trickle charger is great.
DPG is offline   Reply With Quote
Reload this Page 2004 C5 Battery Power
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 Stereo Install Lessons Learned (long) (all text) MSIP Audio/Electronics 10 06-10-2004 07:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
