Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-17-2006, 01:14 PM   #1
adown
CF Senior Member
Default your thoughts on sub configs
I have a 2 ch amp that will run 2ohm per chan or 4ohm brgd( it doesn't say I can run 2ohm bridged). I can either run one ch to each coil(dual VC) @2ohm or run bridged @4 ohm w/vc's in par. What do you guys think?
adown is offline   Reply With Quote
Old 06-17-2006, 02:24 PM   #2
fej
CF Senior Member
fej's Avatar
What are the watt outputs at the 2 ratings and what subs? What efficiency and what RMS recommendations for the subs? 4 ohm bridged has become the popular way to go but IMO try it 2 ohm 2 channel first and then wire it 4 ohm bridged to see what the sub likes better, or more importantly your ears like better
Fej
fej is offline   Reply With Quote
Old 06-17-2006, 04:33 PM   #3
adown
CF Senior Member
The amp is the new Pioneer Premier PRS-D2000T ICE, 300 wtx2@2ohm or 600 wtx1@ 4ohm. The sub is the Premier TS-W3002SPL, eff is .21% and rms p is 1,000, dual 2 ohm vc. I was going to run mono @4ohm, but the other day I read about a "Car Audio"(mag) equipment tester and reviewer ran 2 diff amps to each coil while testing the new Pioneer 5102 sub. So I thought surely I can run a diff channel to each coil, but power is the same so I guess it comes down to how it sounds. I know someones proly been through this. Thanks
Old 06-18-2006, 05:05 AM   #4
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
Bridge it, if you run it each voice coil to each output on the amp you will fry the sub because each voice coil will get a signal one will get left the other right
pentavolvo is offline   Reply With Quote
Old 06-18-2006, 05:06 AM   #5
pentavolvo
CF Senior Member
pentavolvo's Avatar
Reload this Page your thoughts on sub configs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
