Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-02-2006, 01:14 AM   #1
ScottN
CF Senior Member
St. Jude Donor '05
Support Corvetteforum!
ScottN's Avatar
Default How to have portable MP3 and Satellite Radio with Bose HU?
I have a 2001 C5 Convertible without a CD changer.
I have not seen a way to hook up an Ipod and a portable Satellite unit (Roady, Starmate, or similar) to the Bose head unit due to the existence of only one aux input. If there's a way to do this, I'm all ears. I'm not willing to use FM modulation for either the Ipod or sat unit.
So as a compromise, I'm looking at other portable options to have satellite radio and mp3 capability. Here's what I've found so far:
1) Clarion NICE P200 portable GPS. It has a 20 Gb hard drive with 10 Gb for the nav maps and 10 Gb for mp3 storage. You can add a sirius satellite tuner that plugs directly into this unit.
2) Garmin StreetPilot 2730 GPS. Similar to Clarion unit but it has built-in XM capability and mp3 storage (but it does not say how much space is available for mp3 storage).
3) Pioneer Inno. Its a portable XM unit that has 50 hours of mp3 storage.
I'd love feedback on these options or any options that might be available.
Also, I'm assuming that the mp3s I created using iTunes will play just fine on the mp3 players listed above. Am I correct or is the iTunes mp3 format propriety to Ipods only?
Thanks.
ScottN is offline   Reply With Quote
Old 06-02-2006, 07:39 PM   #2
LarryW
CF Senior Member
LarryW's Avatar
Scott,
I believe you could do it using the following interfaces:
PIE GM10-AUX Auxiliary Input Converter
and
Soundgate AUX3 (this thing supposedly gives you 3 AUX inputs )
You would also need the COR-HAR CD-changer harness since you don't have a CD-changer (this plugs into the two AUX port plugs located in the passenger footwell area, the other end would connect into the GM10-AUX adapter):
PIE COR-HAR
Then if you wanted an additional direct-connection to your iPod, you could add this interface (from the Soundgate AUX3 to your iPod's docking connector):
P.I.E. Uni-POD universal iPOD® interface
Regarding iTunes and other mp3 players, as long as the tracks listed in your iTunes library are saved/stored as .mp3 tracks, then you should be able to use them on any other mp3 player (non-iPod).
I believe iTunes, by default, is set to store audio tracks using AAC (Apple's proprietary audio format) but you can easily change this to use additional encoders as follows: launch iTunes, click Edit, then Preferences; click the Importing tab, then select 'MP3 Encoder' in the 'Import Using' combo-box.
Holy @hit Batman, what a @hitload of interfaces!!!
FYI, I have no experience in using any of the above interfaces; just thought I'd pass this info along
Good luck
Larry
LarryW is offline   Reply With Quote
Old 06-03-2006, 12:23 AM   #3
ScottN
CF Senior Member
St. Jude Donor '05
ScottN's Avatar
Thanks for the links! I'll do some research tomorrow.
I already have iTunes configured to record in mp3 format so hopefully I'll be good-to go.
Reload this Page How to have portable MP3 and Satellite Radio with Bose HU?
Tags
aux, bose, c5, corvette, inside, p200, portable, radio, satellite
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
