Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-26-2006, 03:05 PM   #1
EB-Z06
CF Senior Member
EB-Z06's Avatar
Default Factory bose amp question??
I was reading through some of the sticky post and found this..
"The bose interface will give you pre-amp level outputs that you can run to the rca jacks of your amplifier."
Is this true? I can just used the factory bose amp to run the RCAs to my amp instead of buying an line output converter to splice into some of the wires? If so, where is the factory amp located?
I'm not doing a huge audio install or anything. Just simple amp and sub.
Thanks!
EB-Z06 is offline   Reply With Quote
Old 05-26-2006, 03:17 PM   #2
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
you misunderstood. the bose interface is a unit that interfaces with the bose system. sorta like a glorified line output converter.
scott_fx is offline   Reply With Quote
Old 05-26-2006, 03:22 PM   #3
EB-Z06
CF Senior Member
EB-Z06's Avatar
Ah, ok.. Makes sense! Thanks!
Reload this Page Factory bose amp question??
Tags
2002, amp, corvette, factory
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Front Speaker Removal Question chiricon C4 Tech/Performance 10 04-20-2004 12:53 AM
CDT 6 Install Question FYNL4 Audio/Electronics 14 11-15-2003 12:03 AM
Bose door speaker amp question black_89_vette C4 Tech/Performance 10 06-03-2003 05:42 PM
Quick Question about aftermarket HU brackets... carrerarod Audio/Electronics 10 10-25-2002 03:24 AM
Bose: do you have to rewire?? (PLEASE READ, STUCK)! robertpel9 C4 Tech/Performance 48 07-31-2002 03:55 PM
Anyone install an aftermarket CD Player in early C4 w/bose??? FlyboyZR1 C4 General Discussion 21 04-05-2002 02:59 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
