Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-26-2006, 05:56 AM   #1
Gundam
CF Senior Member
Default Depth of the 10" subwoofer hole in the C6?
What's the depth of the 10" subwoofer hole in the C6? Is there additional room to build a baffle and increase the possible mounting depth?
Gundam is offline   Reply With Quote
Old 05-26-2006, 05:26 PM   #2
Gundam
CF Senior Member
I'm trying to see if if a woofer with a mounting depth of 90mm (3.54") would fit in there with a mounting bracket.
Old 05-26-2006, 05:58 PM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
Im pretty damn sure that will fit but I can try and check it out at work
pentavolvo is offline   Reply With Quote
Old 05-26-2006, 07:25 PM   #4
Firsttimer
CF Member
I'd like to know which woofer (if it works), and what will you use for a tweeter and midrange.
Firsttimer is offline   Reply With Quote
Old 05-26-2006, 08:51 PM   #5
Gundam
CF Senior Member
Quote:
I am considering using a pair of DAYTON RS225-4 8" REFERENCE SERIES WOOFER 4 OHM, and they will be run in a 2-way active setup. I'm not sure about tweeters yet since I have to find one that crosses low enough to overlap the woofers (i don't plan on using a midrange.)
Old 05-26-2006, 08:52 PM   #6
Gundam
CF Senior Member
Quote:
That would be great, please let me know. If you can find out the maximum depth I can use (including a mounting plate/baffle) and not interfere with the panels/mechanisms then that would be even better! Thanks.
Old 05-26-2006, 11:27 PM   #7
Firsttimer
CF Member
I'm thinking about putting in 6x9" 3 way Kappas where the Bose subs were, and 5.25" Kappas in the rear, and hopefully getting by w/o a sub. If needed a powered sub could be added later, but there is no great stealth spots.
Old 05-27-2006, 12:57 AM   #8
psykod
Junior Member
It's about 3.5" as I recall from this Post #5 here:
http://forums.corvetteforum.com/show....php?t=1344088
psykod is offline   Reply With Quote
Old 05-27-2006, 05:33 AM   #9
pentavolvo
CF Senior Member
pentavolvo's Avatar
Sorry Its not listed on our database yet I thought it was
Firsttimer I would recommend again 6X9s in the front a 6.5 component will be much cleaner and ditch the rear speakers
Old 05-27-2006, 07:33 AM   #10
Miaugi
CF Senior Member
Miaugi's Avatar
I was looking for a showlow mount sub as well (Blaupunt & Pioneer both have them), but decided to go another route.
I ordered a Pioneer GM6100F amp to replace the stocker (following shopdog's lead on that), will replace the door speakers with Kappa 6 X 9's 2 ways down low and 3-1/2's in the upper spot, 5-1/4's in the rear (rewired for stereo), disconect the center speaker and add an Infinity BassLink into the rear compartment which is a self powered sub (and it can be removed if I need the room).
Not sure how it will sound, but it'll be better than stock and I'm told it should actually be very good?
Miaugi is offline   Reply With Quote
Reload this Page Depth of the 10" subwoofer hole in the C6?
Tags
10, c6, corvette, depth, fit, kind, subwoofer
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
