Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-28-2006, 03:15 PM   #1
rhubarb74roadster
CF Senior Member
Default My VettePC - Pics [Dialup Unfriendly]
Well, I finally got around to taking some pictures of my system. It has been complete for about 4 months and is working perfectly. I had pictures of the whole install, but the SD card in the camera got corrupted and the pics were trashed.
Here are the specs :
VIA EPIA SP-13000 Mobo
512Meg RAM
250 Gig drive
M1-ATX Power Supply
Xenarc 7" Touchscreen
BU-353 USB GPS Receiver
Custom wood box
Windows XP SP2
Road Runner Front End
Map Monkey
Winamp
DIVX Codec
Custom Skin (modified from ones that I found around the Net)
Kicker SX700.5 5 channel Amp
CDT 2-way 6.5" components in front (Crossovers are under the seats)
CDT 6.5" Coax drivers in back
MTX 12" Sealed Sub in an 'NVTHIS' stealth box
RAAMmat BXT and Ensolite over the entire interior and doors.
I used the now familiar method of cutting the entire A/C part of the bezel out and sliding it down. Then mounted the Xenarc frame to the top of the bezel and gluing the A/C framework to the bottom. Then tape up from behind and fill in with the Oatey ABS cement from Lowes. I did not mess with trying to melt my own plastic. The cement was easy to use (get a sqeezie mustard bottle) and readily available. I cut the ashtray door down to half its size and used it to fill the hole in the bottom. My original plan was to mount the computer reset button and Sub level control there, but decided I liked the cleaner look better .. plus it's a great place to lay sunglasses. The sub level control and switches are mounted under the dash. After the filling .. then sanding, filling, sanding, red Bondo glaze, sanding, glaze, sanding, a high fill primer, sanding, primer, sanding, then the SEM Texture paint and SEM Clear finish. I covered up the buttons for the monitor for a more OEM look but extended the wires on the IR recever and placed it behind the grill of the internal temp sensor. Plus the Xenarc has auto turn on/off .. so I really never need the remote.
To move the A/C Controls down, I had to cut out an aluminum support brace in the dash. A Dremel tool was EXTREAMLY handy for this and all the plastic cutting that had to be done for the project.
There is no CD or DVD drive in the car, but I can pull the entire computer out of the car in 20 seconds. I have a 12v power supply in the house I use to power it up and transfer movies/songs/maps/skins to the drive. I also have easy access to the USB ports on the back and can load new music on with a 2 Gig USB Flash drive when I want to do updates in the car. The GPS receiver is mounted right above the brakelight on the passenger side. It is held in place with industrial strength Velcro.
The cover over the sub has holes drilled in it so it can stay on top of the sub and protect it. I kinda over cut the cover a little around the amp and will probably order another one .. then use the carpet from the first to cover the computer.
The PC Box. The motherboard is on the bottom. power supply is mounted to the side, and the hard drive is on the top (upside-down) There are 2 posts that come up through the bottom of the removable panel that fit into holes on the computer case. This holds it in place .. but makes it very easy to lift out. The side of the box that is against the back of the car has 10 holes drilled in it for ventilation. The only fan inside the case is the CPU fan. It is very quiet and the VIA chip does not generate much heat. All the power and switch connections to the PC are on a single connector. The power supply also has a built in sequencer to control the Amp on/off .. that way, the computer has a chance to start up before the amp is turned on .. so no 'THUMP!' The back of the PC is ugly ... but functional (and you can't see it in the car)
The software driving the whole thing is Road Runner. RR is a FANTASTIC program written and maintained by Guino. It's free and there is a great support forum for it over at MP3Car.com. It is totally skinnable and there are many skins that have been created for it. I basically took several different ones and mashed my own together ... moving buttons and functions around. Here are some screen shots .. sorry for the bad quality .. time for a new digital camera.
Props to the original authors of these screens (most from MP3Car.com)
Right now, the hard drive has about 15,000 songs, 50 movies (in DIVX format), about 100 audio books, and a bunch of comedy albums .. and there is still over 100 Gig free. Song/album selection is very easy .. no mouse required. It is also possible to build playlists on the fly and shuffle at will. Who needs XM!
As soon as someone comes out with some good Bluetooth software for the Blackberry, I will add Bluetooth to the PC and an in-car mic for phone calls and voice commands.
So there you go. I could not have done it without the help and support of this forum and MP3Car.com. If you have any questions .. hit me at rhubarb9999@gmail.com
Thanks for listening.
Oh .. the Car :
The Lexus SC300 in the background is my daily driver .. it has a CarPC too !
rhubarb74roadster is offline   Reply With Quote
Old 04-28-2006, 03:57 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
looks awesome... nice job
pentavolvo is offline   Reply With Quote
Old 04-28-2006, 04:24 PM   #3
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
looks great.....im lovin these carputers
DPG is offline   Reply With Quote
Old 04-28-2006, 05:02 PM   #4
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
looks great! you should look into the vst plugins that can be used with RR. How does RR run on the epia board?
scott_fx is offline   Reply With Quote
Old 04-28-2006, 06:05 PM   #5
edensknight
CF Senior Member
edensknight's Avatar
Congratulations! Very cool! Great DIY audio visual PC mod!
edensknight is offline   Reply With Quote
Old 04-28-2006, 06:13 PM   #6
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Very clean install - nice job.
Vetteman Jack is offline   Reply With Quote
Old 04-28-2006, 07:25 PM   #7
scott_fx
CF Senior Member
scott_fx's Avatar
we need a subforum for all the car pc guys
Old 04-28-2006, 08:21 PM   #8
brian ns04
CF Senior Member
brian ns04's Avatar
Great job! You guys blow me away with the talent you have.
brian ns04 is offline   Reply With Quote
Old 04-29-2006, 12:15 AM   #9
Freestyler
CF Senior Member
Freestyler's Avatar
very tidy
for that size, ya coulda........nevermind, sweet projectloveyour work on the dash!
Freestyler is offline   Reply With Quote
Old 04-29-2006, 12:25 AM   #10
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
Quote:
I think there would be a whole 3 of you guys there and the rest of us to drool over your creations
Old 04-29-2006, 07:08 AM   #11
comp
CF Senior Member
comp's Avatar
Quote:
comp is offline   Reply With Quote
Old 04-29-2006, 01:32 PM   #12
1bdvet
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
1bdvet's Avatar
SWEET
1bdvet is offline   Reply With Quote
Old 04-29-2006, 11:39 PM   #13
wicked 98z
CF Senior Member
wicked 98z's Avatar
Send a message via AIM to wicked 98z
man i want something like that. What kind of price would I be looking at if I was to do that
wicked 98z is offline   Reply With Quote
Old 04-30-2006, 01:56 AM   #14
scott_fx
CF Senior Member
scott_fx's Avatar
wicked...for basic computer you're looking at about $1200 you'll need an amp as well and might as well go with speakers as you start customizing you'll see the price go up quickly but it sure is fun! I finally found a soundcard that meets the voltage output that most good quality h/u have, and you always can get a usb dac for even better sound quality. the sky is the limit!
Old 04-30-2006, 09:38 AM   #15
rhubarb74roadster
CF Senior Member
I was able to put the computer together for around $875 including the monitor and cable. I can send the links if anyone is interested.
That does not include a case or any kind of CD/DVD drive.
With the amp, speakers, sound deadening, materials for the bezel, wire, and misc stuff the whole project came to $2000. I bought the amp used from eBay, the door speakers from a forum member here (including the door mounting plates), and the sub from a forum member.
I am using the on-board audio from the motherboard to feed the amp directly. The amp has a built-in crossover for the sub. I am happy with the sound quality but always tweaking the EQ to get it a little better. I used to own a recording studio .. so I am a little picky when it comes to sound ScottFX pointed me to the VST plugins .. so I am going to try an EQ module I found for that and see if its better.
Most of the work is in the bezel. It's not hard to do, but you have to go slow. If you mess it up, a new one is $100 (ask me how I know).
Old 04-30-2006, 09:51 AM   #16
AGENT 86
CF Senior Member
AGENT 86's Avatar
AGENT 86 is offline   Reply With Quote
Old 04-30-2006, 11:47 PM   #17
NVTHIS
CF Senior Member
NVTHIS's Avatar
Looking Good!
__________________
1999 Nassau Blue FRC complete Z06 conversion
N/A: 407.55 rwhp, 385.02 rwtq
Tuned by Charles Barber and V8muscle.net
Mods: Halltech ported TB, Halltech Tric, Kooks LT's, Kooks x-pipe w/ Hi-flow Cats, ECS "Big" Blower cam, Manley Double Roller TC, Comp cam high tech pushrods, Patriot Extremes, Pinned Crank, NGK plugs, MSD wires, 160 T-stat, B&B Bullets, Bilstein Sports, Textralia OZ700, Remote speed bleeder, Nassau blue depos, Tigershark Fascia, Mallett 396...
NVTHIS is offline   Reply With Quote
Old 05-01-2006, 01:23 AM   #18
00Hawk#140
CF Senior Member
00Hawk#140's Avatar
Thats really cool ! Glad my wife doesn't look at this site..... or else she would want one !!!
Tim
00Hawk#140 is offline   Reply With Quote
Old 05-01-2006, 01:26 AM   #19
scott_fx
CF Senior Member
scott_fx's Avatar
hmm.. i think i was including the alpine pxa-701 in the $1200 quote.... can't remember though.
I didn't know you were using onboard audio! do yourself a favor and go online and buy yourself a used soundblaster live 5.1 for about 10 bucks on ebay. then download the 'kxproject' drivers and you'll open yourself to a completely new experience with system adjustability! I paired this up with an audio control line driver/x-over and i was amazed at the sound quality improvement as well.
if anyone is interested i have a lot of the pieces to my old system laying around. pretty much the entire thing sans the computer itself (even the pxa-h701 got ripped out today) pm me if you want details ...sorry you can have you thread back
Old 05-01-2006, 01:32 AM   #20
bogus
CF Senior Member
Send a message via Yahoo to bogus
that is just too cool!!!!
bogus is offline   Reply With Quote
Reload this Page My VettePC - Pics [Dialup Unfriendly]
Tags
carputer, halltech
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
