Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-27-2006, 10:37 PM   #1
NEVRL8T
CF Senior Member
NEVRL8T's Avatar
Default Need help diagnosing problem
I have a 1992 C4 with the stock Bose Gold system in the car. The rear speakers most of the time have a loud squealing noise emitting from them. I can turn the radio up (sometimes) and not hear it or sometimes it is at such a high volume I just turn the radio off. Sometimes turning it off and on makes it go away. It will also pop loudly while this is going on. I have unplugged each of the rear speakers one at a time and it it still makes the sound. If I unplug the left the right does it and vice versa. I have unplugged both so I can listen to the radio through the front speakers to avoid this embarassing situation. It really is loud when it does it. What is going on with this car's stereo? I have read all through the audio sticky's and searched but could not find any leads in the search directory. I know nothing about car sound systems so if anyone can provide help I would be very grateful. Thanks!
NEVRL8T is offline   Reply With Quote
Old 04-28-2006, 01:36 AM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
this sounds like a classic case of blown caps on the amp.
I reference it in the C4 Audio FAQ... and I think there might be a link to a fix somewhere within the FAQ...
bogus is offline   Reply With Quote
Old 04-28-2006, 01:49 PM   #3
red_johnny
CF Senior Member
red_johnny's Avatar
Send a message via Yahoo to red_johnny
Quote:
I would look more to the grounds, maybe even rewireing the rear speakers with thicker wire. Maybe a 14 GA would work as it would be thick enough to stop any interferance that MAY be happening. Honestly its really hard to isolate what exactly is going on. Work from the easy fix on up like pulling the radio out to check the grounds. The most important one you need to be looking at is the rear speakers (DUH) ground, it might be wired with both grounds into one then all you need to do is make sure it is solidly grounded to a ground point.
red_johnny is offline   Reply With Quote
Old 04-28-2006, 02:40 PM   #4
NEVRL8T
CF Senior Member
NEVRL8T's Avatar
Thanks for all the help. I do really appreciate it.
Reload this Page Need help diagnosing problem
Tags
94, bose, corvette, diagnose, gold, system, working
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need help diagnosing oil leak and smoking...somewhat long. tshort C3 Tech/Performance 31 01-03-2004 10:44 PM
Need help diagnosing problem with front wheel drive car tshort C3 Tech/Performance 12 03-28-2003 04:33 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
