Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-21-2006, 11:33 PM   #1
TheRadioFlyer
Supporting Vendor
St. Jude Donor '08
1997 Chevrolet Corvette
TheRadioFlyer's Avatar
Default who'se done a custom amp rack
i'm planning a sound system for a C5 coupe that will involve two alpine MRP f450 amps (front and rear speakers) i'm thinking about building a custom amp rack that will have each amp mounted at an angle behind each seat. (really like idea of using a plywood base to mount the amps on and epoxying it to the car)
any advice or pix?
TheRadioFlyer is offline   Reply With Quote
Old 04-22-2006, 12:55 AM   #2
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
i wouldnt epoxy it to the car unless that was my last resort. if you're going to have the amps directly behind the seats then i probably would try to see if there was a way i could make the board in a lazy 'l' shape (to follow the contour of the wall behind the seat) and then see if i can mount it using the existing seat bolts (maybe get some longer grade 8 bolts an a metal strap to secure the bottom part of the 'L'. doing it this way you dont have to worry about supporting downward force because the floor of the car will do that, and then bolting it to the existing seat bolts will take care of lateral forces and keep the amp rack in its place. i'm not sure if this could be done...but worth looking into. onther option is to silicone or liquid nail a piece of wood under the carpet against taht vertical wall and then use that as a base to mount the amp rack to. this way it can be removed further down the line.
if you are talking about the area behind the seats....in the 'trunk' area. if you have a vert you can get away with a friction fit since you have the waterfall to protect youfrom flying amps in the event of an accident. if not, apply the silicone technique that i described above to that location.
check out the link in my sig for some pictures of mine (done with a friction fit method)
__________________
'99 Navy Blue
Engine: Borlas, Vortech, HRE 547R, TTS headers, Engine built at A&A (220 - 224 Comp X-ER .581 lift, A&A Stage II ported LS1 heads)
Audio: Car-PC, Butler/Phaze Tube Amps, Dyn/Seas, Zapco, TC-sounds
My Car PC Install
2003 Honda Cbr600RR
2001 Volvo S60 t5
1997 Suzuki Gsx-R 750
Old Car:
1993 Mazda Rx7 R1
scott_fx is offline   Reply With Quote
Reload this Page who'se done a custom amp rack
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
